4g64 question!!!
4g64 question!!!
ok so i found a guy that will give me his 4g64 motor so i can swap it into my evo. i noticed that its only a single cam motor though. will our head bolt right onto the block and be fine? and what else do i need to modify on the motor to put it into my car? ive heard of people getting them drilled with oil squirters or something?
Read this. It will give you some good insight:
http://www.importtuner.com/tech/impp...ion/index.html
Power enterprise, it might be $230 and 5 weeks but they dont blow. Add some L19s and its golden.
Look at my build that was all a 4G64 block. Your choices on motors with the 4G64 and "off the shelf" parts are pretty easy since Magnus stocks lots of Ross stuff for that motor.
2.1 is the 88mm 4g63 crank, needs at least 156mm rods to keep piston weight down and that is trade off in price. If thats not much of an object you can also do 162mm rods.
2.2 (like mine) aftermarket 94mm crankshaft, 156mm rods or 162mm rods.
2.4, cheap & torquey.
The 4G64 isn't any different than a 4G63 block except the larger bore. I don't understand why people keep saying that. As long as you don't bore the block too large (87.50mm+), it should be no different than a 4G63 engine. Power Enterprise makes a large bore gasket and is the way to go. At this time, nobody makes a MIVEC specific gasket for a large bore...I'm doing some research myself to find a solution.
