how much low end do you loose?
I am planning on changing my exhaust system to a full 3" from the turbo all the way back. I was wondering how much of a low end will I loose. I know I will get hell of a top end. should I just go from the cat. back? or 3" downpipe-stock cat.-RMR exhaust? or stock downpipe-3" cat.-RMR exhaust? How are you guys set?
thanks
thanks
I wouldnt say ur going to lose low end.... IMO u will gain low end because a 3" exhaust should help the turbo spool faster and by doing that u will have more low end. Good luck.
I cant say for everyone else but I have Buschur Racing 3" turbo back exhaust(test pipe) and beyond 3k rpm it just screams till red line. Under 3k rpm you can tell that it lost alittle low end grunt not by much. 3k rpm comes into play so damn fast its not even funny. Oh, also noticed that boost went up a notch(1.4bar instead of stock 1.3bar). I am amazed that with the test pipe in, it didnt throw a check engine light.
Thai
Thai
Thai
Thai
That's true LSs1power, I guess the power is so smooth under 3krpm that it feels like you lost power but on an actual dyno you will see that you do gain power.
Originally posted by ItsStockOfficer
You don't lose low end on a turbo car from exhaust.
I even thought after I even installed my Intake I lost something (felt a little slower at lower RPM), however with the full 3'' so much power top end is sweet. The only way to go IMO. Happy here with Buschur!!
I love hearing people repeat the ever so simple concept bigger is better when it comes to the exhaust for a turbo car.
The statement is true for peak horsepower maybe. But it is completely not true for all around performance.
When I first built my yellow car it had a 2.3 liter with vpc and 2.75 downpipe only. Running a 57trim/stage3/48. It made 10psi at 4000 rpm and made 20psi by 4300rpm. i drove the car for three months or so with just the downpipe. When my ears couldn't stand it any longer I built a three inch exhaust for the car. To my pleasant surprise the car made 10psi at 3200rpm and 20psi by 3900rpm. These numbers are not an exaggeration.
I have a similiar story of massive torque loss on another car of mine switching from 2.5 to 3.0 exhaust. The resultant torque loss was extremely disappointing.
jimmyv65
Mar 13, 2006 05:59 PM
JRock
Aug 27, 2003 02:52 PM
Alfriedesq
May 19, 2003 11:45 PM
