Anybody using 1.3mm Cosworth Head Gasket on 40psi+ boost?
The difference in thickness is minimal in this instance, but thicker isn't better. One primary concern about thicker gaskets is they move the surface of the head further from the piston deck, and if that space becomes large enough, it increases the chances of detonation. That shouldn't really be an issue here, but the basic point is thicker does not mean better.
