removing head?
there is a 10mm bolt holding the large coolant passage to the head/thermostat housing. its very hard to see because on the 9's its upside down under the TS housing. since you said you can't find it and its on the driver side, give that a look.
yes, underneath it. one 10mm bolt upside down. you'll likely have to remove the battery and tray if you haven't already.
edit, just follow the big metal goldish colored coolant passage that goes along behind the block, under the thermostat housing. you'll see a tab that holds it to the thermostat housing, and just takes the bolt out.
there's also a 12 mm bolt I believe on the upper right corner of the block, I believe it goes through the coolant tube and into the block, that's what held me up a bit kinda tough to get to but patience should help
In this pic you can see the two dowels coming out of the block.
the 12mm bolt goes into the block, not the head. it wont hold you up if your just removing the head. the 10mm bolt i was talking about does hold the head to the cooland line though (which is attached to the block at the water pump and the 12mm bolt into the block under the intake manifold)
11
Jun 5, 2014 07:58 PM
SCR
May 28, 2010 07:27 AM
