New GSX eclispe turbo into evo 9.
You would need a manifold such as this one from JMF:
http://www.jmfabrications.com/site/i...mart&Itemid=58
For the cost involved, it wouldn't be worth it considering you'd be getting a compressor wheel that's barely larger than your stock turbo, and giving up your twin scroll turbine side.
Well i got the turbo for 200 brand new from a really good friend whos gsx got flooded out. Im also getting re-tuned in two weeks so with a bigger turbo hopefully i can get better numbers.
Just to make sure you understand the other thing about this, For the work reconfiguring your downpipe and intercooler pipes you still wont make more than the stock 9 turbo. A MAXED out Evo3 makes 450+whp on E85, and I have never seen a 20G that I thought was worth it outperform an Evo3.
Save the 200 and look into a used Red or speed density since this is likely to give you as much as the 20G would have. Was it a legit real Td06 20G? I mean not a sleeper 20G or Hahn 20G?
The tomei turbo, map sst. and the original 6 blade green are all exact duplicates of the 20g wheel. they all outperfrom the evo 9 turbo.
but to answer OP question. you do not want to run a dsm turbo on evo 8/9 platform.
need_an_evo
12
Jan 18, 2018 11:02 AM
GSX 911
Jan 14, 2013 08:24 PM
Lazukard
22
Jul 27, 2011 06:14 PM
