Synapse Synchronic BOV installed
Old Aug 9, 2010, 11:19 AM
  #106
Synaptic Evo's Avatar
Originally Posted by boostedwrx
Hey Synapse/Devin - can I send my Synchronic in and have you guys update it with all the new features? I already have the model with port C removed obviously but it looks like you guys are using bigger hardware for the ports on top, etc - thanks.
We actually have a kit together that includes a boost connect kit and the 1/8th NPT upgraded back cap.
the price for this will be 39.99
Old Aug 9, 2010, 11:27 AM
  #107
wizzo 8's Avatar
What about a kit to delete c port?
Old Aug 9, 2010, 11:30 AM
  #108
We do this service in house for $30.00 that includes shipping back to you.
Old Aug 9, 2010, 11:34 AM
  #109
wizzo 8's Avatar
That's great and all but this is my d/d. Guess ill just keep the c port
Old Aug 9, 2010, 11:46 AM
  #110
hmm i know there is a nice evo guy out there who wouldnt mind letting you borrow a stocker
If anything give us a call and im sure we can work something out.
Old Aug 9, 2010, 11:55 AM
  #111
wizzo 8's Avatar
Ill probably just do it this winter when I rarely hit full boost. Ill give you a call then. Thanks
Old Aug 9, 2010, 12:59 PM
  #112
boostedwrx's Avatar
Hey Devin I'll send you a stock BOV to rent out to people if you update my Synchronic to the 1/8th NPT back cap
Old Apr 4, 2011, 07:57 PM
  #113
wizzo 8's Avatar
Ill be ready to do this when my motor is out at the end of the month. Who do I send it to and whats the turn around time? Thanks
Old Apr 5, 2011, 12:05 PM
  #114
awdordie's Avatar
Originally Posted by Ted B
Mine is configured exactly the same way, and I've never encountered so much as a hiccup either.
Those signal lines need to be straight connections and free of tees. Some in here have MBCs and whatever else tee'd into the BOV signal lines and wonder why they can't get it working correctly.
^exactly, the directions are there for a reason and it clearly states in the manual not to tee it off and shows u how its suppose to be ran to avoid problems.
Old Oct 9, 2011, 12:09 AM
  #115
despat's Avatar
Denin
Need some help setting up Synapse bov and Synapse WG with Eboost2 selnoid.
I've attached a picture. Actually, my car is bone stock so I need to be at 3-6 psi. I know the eboost/selenoid is an overkill but I fancy the greater control even at the high price. Can you run by the picture below so confirm the setup.
btw, I'm removing the main spring and running with only preload spring in the wastegate so that I can lower the psi to 3-4 and control the max cutoff at 5-6-7 psi.
As for the BOV, what should I connect the boost vaccuum source to? A or B or A and B.
Is the C port on the BOV connected correctly (tee of at the turbo compressor)?
Old Oct 10, 2011, 03:30 PM
  #116
Mosaic's Avatar
Question Simultaneous Electronic control of WG & BOV
Hi Synapse,
Not to hijack your thread but would Synapse be interested in testing/ evaluating a new controller built to simultaneously drive both the BOV and a WG/EBC with multiple 3 way solenoids for full multimap dashboard tuning of both? Complete with digital displays and a boost spool dyno for verifying the tune. Suitable for Diesel apps as well.
In addition to those controls you can even dial out (digitally) partial throttle turbo surge and defense lean boost conditions without altering the turbo setup, fueling or boost targets.
The controller offers superior control with proportional blow off based on boost pressure as well as proportional boost targets based on throttle position. Multiple safety interlocks and BOV emergency POP off etc. Triple PID Closed loop or Open Loop maps.
The product has entered the final testing phases and I am hoping to make it available to interested manufacturers of WG & BOV to further enhance their product lines.
Old Oct 10, 2011, 05:07 PM
  #117
boostedwrx's Avatar
^ my thread and yea, total hijack
mrfred
537
Jun 20, 2022 09:50 AM
Hiboost
17
Jul 19, 2019 09:01 AM
High_PSI
119
Oct 4, 2016 08:20 AM
SsZERO
Nov 13, 2010 09:56 AM
05blue8
23
Jun 19, 2009 01:39 PM
Quick Reply: Synapse Synchronic BOV installed
