Double Pumper N AEM
Double Pumper N AEM
I will be using a double pumper with my car thats running AEM EMS.I don't want to run a Hobbs switch.How would i go about running 2nd fuel pump via ems.How would it work.Is it linearly controlled?ie pump on at 10 psi(boost) @ 25%, 15 psi 50%,20 psi 75%, and 25 psi 100%?Or is it 15 psi 2nd pump on full blast?I probably have to wire relay to one of the available outputs on aem i guessing.Thanks.
