will a evo 5-6 drivetrain fit in evo 7,8,9?
what about the rear mount and rear mount bracket thats bolted to the subframe ? Is the rear mount and mount bracket different from the evo 8 and mr ? thats the only thing i can see that can be the problem. ill check part numbers to see if its the same .
Engine and trans yes , tcase is a no go. The center diff out put to the trans / tcase is the same so all you need is a 8 t case. The 6 has a different subframe so the tcase is different. We have a customer who has an EVO 6 TME. We swapped in an Evo 8 engine and trans since he blew his engine and trans but we had to keep the 6 t case.We could have made the 8 t case work with some fab work. Another problem was a few weeks after the swap he blew up the tcase(front diff) so we had a machine shop modify an Evo 8 tcase internals to work in a Evo6 t case. If it were me i would just try and get an 8 drivetrain it is a PITA when parts break on the EVO's never offered here in the States especially if it is a DD.
i dont have either the transfer case or the car in front of me so i cant compare, if its a simple case of making another bracket to mount the evolution 8 then thats easy, but if its a whole **** ton of welding/fab in order to get the 8 transfer case to fit then ill just settle for the evo 6 unit.
I own 2001 Evo 6 TME. You can fit engine,trans,rear diff to Evo 8. 3 engine mounts are the same, just the rear engine mount is different. Front traverse is different you cannot use E6 transfer with your existing one ( unless you fabricate smt special). CP9A transferbox's have smaller casings according to CT9A.
hey...i have more or less the same question..i have and evo 7 which im selling and have and evo 6 which i want to keep but im want to swap the engine and trans of the 7 to the 6 ...the gear ratios are the same? no problem with that? and the same for the 7 with the 6 engine and trans? thank you
if you are going to use Evo 7-9 transmissions/T-case, stay away from the 7s. The T-cases are actually different internally than the 8/9's and are weaker.
I have shattered my stock evo 7 T-case below 400 WHP. Currently running MAP beast mode T-case now over 400 WHP. No problems.
WTB[SouthEast]: Wtb Evo 8 Non ACD Transfer case
Evo47
Jun 15, 2016 07:38 PM
steinvb12
Feb 12, 2016 09:18 AM
Ian0611
Dec 17, 2015 02:27 PM
memphis raynes
10
Jul 9, 2012 04:04 AM
