Driven Innovations Inlet
Hi Lads
Im currently in the lookout for the Driven Innovations Inlet Mani,but have a few qusetions...
I beleive there are two sizes...is this correct? Small (for stock TB) and Large plenum for Q45 TB.....Correct?
And secondly can i use the stock Dip stick with this plenum?
P.s Car is Evo VI 2ltr with Ets Cooler and Garrett GT3582r
Hi Lads
There are 2 sizes small plenum and large plenum. Small plenum only uses stock TB. The large plenum uses any TB ford, stock, Q45.
Manifold is setup to use your stock dip stick.
I suggest small plenum with stock tb for your setup.
I was going to order the larger Plenum, with 95mm Q45 TB Good news regarding the dip stick mate....but why do you suggest the smaller Plenum with standard TB??
I would like to hear your views on this mate
Cheers
Craig
It all depends on your ultimate goals. Small plenum stock TB will provide great spool and a stock like driveability. The large plenum and large TB will spool slower but will make more power at higher RPM.
Erik@MIL.SPEC
365
Aug 29, 2017 12:59 PM
Enclavet
May 6, 2016 08:26 PM
Demon_ni2
12
Dec 13, 2012 10:52 PM
4g63girl
Apr 13, 2012 12:50 PM
justin123456789
21
Jan 7, 2010 12:05 PM
