Turbosmart e-boost street for 2010
Old Feb 13, 2010, 03:43 PM
norcalSRTrida's Avatar
i have to say, the one thing I DO like about my boost gauge is you can self-calibrate it anytime/anywhere to correct for elevation or if its off slightly.
paid 129 for my VEI digi gauge... reads to -30vac, and up to 60psi which is great..1 time buy. the bar graph sweep around the numbers can be changed to "max" at 12, 24, 36, 48, or 60 psi...can have it show a full number, or in .5, or in .1 increments...so it could be 25psi, 25.5, or 25.7 depending how u like it to read.
im not a fan of the digi gauge in terms of spool up reading, but under wot and everything else, it sure beats the inaccurate mech gauges i've owned...
Old Feb 14, 2010, 11:07 AM
BluEVOIX's Avatar
Originally Posted by n2oiroc
i was told by a very reliable source that the street models suck, the regular round eboosts are great though.
What exactly sucks about the boost controller?
Old Feb 15, 2010, 10:47 PM
soceur77's Avatar
bump
Old Feb 15, 2010, 11:08 PM
rodent's Avatar
I've heard nothing but good things with the e-Boost2 controller.
I was thinking about trading in the Hallman Pro for this.
e-Boost2 – 60psi
Now standard with 60psi max boost operating pressure!
e-Boost2 is a second generation complete Boost Management System. With market-leading features and and state-of-the-art software, e-Boost2 is the one accessory all owners of turbocharged cars should have! Easy to use, yet sophisticated and technologically advanced, the e-Boost2 is equally at home in a street-going vehicle as it is in a top-level racecar.
e-Boost2 allows the user to control, monitor, map and compensate boost. But e-Boost2 is a lot more than just a boost controller – it can also control water spray, methanol or nitrous injection, manage shift/warning lights and read/monitor RPM. While e-Boost2 is fitted with a state-of-the art software, it has been designed to be easy and logical to use.
Boost Levels: up to 6 levels of boost.
Boost on Demand: provides instant overtaking power at your fingertips
Gear-based Mapping: set a different boost for each gear!
Adjustable Boost Levels: program boost against TIME or RPM.
Aux Output: fully programmable; controls water spray, methanol or nitrous injection.
RPM Compensation: eliminates boost drop-off at high RPM.
Peak Hold/Max Boost Recall: monitors boost and RPM.
Gate Pressure: eliminates wastegate creep.
Overboost Shutdown: provides added protection for your engine .
Display: programmable, can be configured to KPA, Bar or PSI.
Auto Dimming: with backlit buttons for hassle free navigation.
Aceessories: dash and roll cage mounting kits, shift/warning lights and a full range of spares.
Old Feb 16, 2010, 06:16 AM
mt057's Avatar
That does seem pretty cool but why does it say six levels of boost? Do you have to go with preconfigered boost levels or can you fully adjust it?
Old Feb 16, 2010, 06:36 AM
n2oiroc's Avatar
I dont have the email anymore but i though it was something about spool or the solenoid it uses.
Old Feb 16, 2010, 06:39 AM
SPECJUNK's Avatar
ive used an eboost2 for a few years now, and still my only complaint is the way you have to navigate through the different parameters. i wish someone would come up with a boost controller that you could just tell it 25# and it would have enough brains to make it happen! no more need for all the extra nonsence.
Old Feb 16, 2010, 08:39 AM
ChrisCarey's Avatar
I believe what you are referring to are the boost presets, you can fully adjust boost to your needs. Also, we're a Turbosmart master distributor if anyone is interested in any of their products We have several of the 30psi eBoost streets that are on clearance as well, pricing is ridiculously low!
Old Feb 16, 2010, 08:46 AM
MitsoKid's Avatar
I had one of these on my car. I wish the manual wasn't an inch thick, haha. I will buy one again though
Casey Robertson
Mar 21, 2016 08:25 PM
Gary@MellonRacing
Sep 25, 2010 04:07 PM
SRT-TO-EVO
11
May 15, 2008 07:32 AM
500whp.com
13
Mar 16, 2005 04:27 AM
Quick Reply: Turbosmart e-boost street for 2010
