2.2L 4G63 VS 2.2L 4G64 Long Rod
Your question more or less lies between whether anyone thinks a 4G63 or 4G64 is better...
Things to consider:
Oil squirters 4G63 > 4G64
Not having to Degree Cams 4G63 > 4G64
"Custom" Water Pump/Timing Belt 4G63 > 4G64
Cost 4G64 > 4G63
Better R/S 4G64 > 4G63
I'm a noob but ths is what i've gathered, take it for what it's worth.
Things to consider:
Cost 4G64 > 4G63
Update! 10.0:1 compression, steel rods, still can't make up my mind on the 4g63 85.5mm bore OR 4g64 87.0mm bore??? For 20k miles a year, which one is better? Oh ya, I need to be in the low 10's in the 1/4 mi too!
Things to consider:
Cost 4G64 > 4G63
Things to consider:
Cost 4G64 > 4G63
Things to consider:
Cost 4G64 > 4G63
Things to consider:
Cost 4G64 > 4G63
Can I beat this dead horse?
Whatever happened with this build?
Did you end up going with the 4g63?
https://www.evolutionm.net/forums/pr...4-efr7670.html
If he was smart, he did a 4G64 with the 94mm crank, 159mm rods and drilled the block for squirters. The thread I've posted has me rethinking my build, except that I already have everything but pistons for my 2.0..
Hopefully this will /thread.
R/TErnie
80
Jan 7, 2021 02:46 PM
