oil cooler evo8
oil cooler evo8
looking for an easy setup, is there any oilcooler "plug`n`play" to change my stock one, I`d like the one with thermostat and fan if possible
also would like to know the size of the biggest one which can be installed
thanks
thanks
You want an oil cooler with a thermostat and fan? I don't know of any kits that come with that.There are a lot of upgraded oil coolers, AMS, STM, and MAP all sell upgraded oil coolers but I dont think they are available to come with thermostat and fan, I could be wrong though.
the idea of installing a larger cooler also gives you a possibility to enlarge the ammount of oil in system, unfortunately I dont have oil temp gauge( and I can check the temp but first of all i will install a thermostat that opens on 75 degrees celsius versus 100 stock
I was also interested is there any cooler which will fit stock fittings
I dont have the oil temp gauge, but I think with my mods:
2.3 stroker
Cosworth M2 cams
Precision 1000cc
Perrin fuel rail
Largest Perrin intercooler
3" exhaust
Injen intake
FpRed 84mm ported
FullRace street manifold
65mm throttle body
oil cooler is needed, I was just wondering is there any for factory fittings
ATM I decided to install Earl's, PN42508.
2.3 stroker
Cosworth M2 cams
Precision 1000cc
Perrin fuel rail
3" exhaust
Injen intake
FpRed 84mm ported
65mm throttle body
WTB[MidWest]: WTB Aero lip
counterforce661
Jan 21, 2016 08:52 AM
TheMadScientist
53
May 5, 2011 04:23 PM
Gts_BlackJoker
Mar 2, 2008 07:45 PM
