UICP and LICP
UICP and LICP
i am really interested in knowing if changing the intercooler pipe will have any proven gains. they sell the licp and uicp like crazy in the fs threads and i want to know if its worth buying on my stock fmic. thnks
Absolutely, do both lower is where the real gains will come from but the upper is also worth it imo. There is all kinds of after market intercoolers that use stock location pipes so don't let that hold you back if you do plan on upgrading the ic. Good luck with your decision.
And, I am selling an Injen UICP... you can use with your stock battery.
https://www.evolutionm.net/forums/sa...njen-uicp.html
I do not believe there is much difference in gains between a short route with mini battery vs a regular route aftermarket piping.
The UICP does not really offer much gains all in all, the LICP is where spool is much quicker and gains can be made. ETS LICP has shown to make more hp than other brands. I recommend ETS LICP and try to find an UICP that also includes an intake pipe, such as injen which I also recommend.
All in all, aftermarket UICP may be the least bang for the buck.
I felt the lower pipe for sure not sure for the upper very minimal gains little or maybe none..Note i made 500 whp with stock upper pipe..lol..I only changed because i went with a tial bov.
I am considering the LICP my only question is I am running the stock type set up I currently have an HKS drop in filter (wich will be replaced with either a perrin or K&N reusable type drop in ) with a rex speed stock style snorkle, would the LICP be a good next step?
