IX stock boost control, + few mods should = xxx boost?
Hi guy I did do a little searching before posting but nothing came up in relation.
Recently purchased a IX, and when I picked up the car it had a Turbo XS mbc installed. The previous owner told me he "turned down the boost for me", so I could get the car home without any problems of blowing IC hoses off during the 11 hour drive home. This yielded about 14 psi spike and hold.
After getting the car home I attempt to turn up the boost by turning the BC in relation to the + setting on the turn knob. After about 5 times of trying to turn it up, only seems to raise to about 17 psi.
I've checked all of the IC clamps, no major boost leaks to be found. Next step was to install the stock boost lines from an VIII (since the IX did not have any) After installed the stock boost line the car will now only boost to about 15 psi.
I have the red tipped hose running to the wga, the other short end off the T going to the J pipe, and the other end of the hose going to the front most nipple on the stock boost solenoid, the brass boost pills are located in the long hose, and the hose on the j pipe.
I was under the impression that a stock IX should reach around 19-20 psi of boost. Temps are low here in the teens and 20's. Even with full 3" exhaust I would think the boost should be higher. Is there anythng I'm missing or doing wrong? I've never had stock boost, or stock boost controller on any of my EVO's.
When I was in process of buying the car the owner told me he was able to peak like 28 psi and hold 20 ish with the MBC. At the time he did have a forge bov, and I requested the stock IX bov when I bought the car. Even so. I have tried two ix bovs now. Stock one, and my personal IX bov from my VIII, which held 24 psi till redline on the stock turbo, so I'm sure the bov is not the problem.
Did you fully adjust the MBC and turn it from fully closed to fully open? 14-15 is about right for WG pressure. You should be able to adjust that up to at least 20 with the MBC.
Also, I assume there have been problems blowing the pipes off on this car? Have you replaced the clamps with t-bolts? Also, what boost level is it tuned for?
The car was said to be tuned to run pretty aggressive. Has personal claims of the car running 11.8xxx at the track, from when he posted times of the car last year. I installed a wideband right away and V7 so I could monitor to see if there is any knock. Have not had a chance to log yet.
The BC is this one http://http://www.turboxs.com/uploaded_images/521.pdf
Which is how it was when I picked up the car. I also hooked it up like this http://http://www.jonesland.com/evo/MBC_Install.htm
Did not seem to change at all.
EDIT.. I think I may have found something. It looks to me like there is 0 duty cycle right now for the wg. I'm looking at my V7 (which is new to me, just learning how to play around with this stuff) However it looks like my boost table is all o.o for every gear. I'm not 100% sure yet, but I will turn it up and reflash and report my findings.
Chukee_R
17
Jul 2, 2007 02:03 PM
Sgt Blamo
Dec 4, 2005 01:26 PM
Mr. Stock
Nov 10, 2005 06:37 PM
