Car appears to stutter/sputter over 30 psi
Old Mar 4, 2010 | 08:35 AM
SmurfZilla's Avatar
So I recently upgraded to a BBK Full (ported) and I have had an issue with the car sputtering or kinda stuttering over 30 PSI. I thought it was a major boost least at higher boost so I decided to by IC piping and a bigger FMIC (I kept blowing the stock hose off at the manifold....ended up breaking a old tbolt clamp I had).
After putting everything I kept blowing apart the IC piping on the UICP....Up until this morning I wasn't able to get a good run up through the gears. On my way into work I finally tightened everything down to where its holding together but I'm still breaking up at higher boost/PSI.
I'm thinking that it can be only one of 2 things. Either I need to upgrade my ignition system (At 30-35psi on a BBK full is this necessary) or my plugs need to be changed (I have about 20,000 miles on the current set so I'm thinking of replacing them and going one step colder).
Any ideas or suggestions on what else it could be? This is baffling me and I want to resume tuning the BBK but I'm at a standstill right now.
Old Mar 4, 2010 | 08:59 AM
jos's Avatar
jos
plugs or fuel
Old Mar 4, 2010 | 09:24 AM
SmurfZilla's Avatar
Its been happening for a few weeks I've filled up E-85 from 2 different gas stations.....unless an injector is going bad or something.
I'll be looking form some plugs locally I'd like to resolve this by the weekend if possible.
Old Mar 4, 2010 | 10:25 AM
lbcevo's Avatar
It's a misfire. Try some new NGK BPR 7 or 8 EIX Iridiums before changing ignition. Much cheaper and they misfire less than copper and don't foul.
Old Mar 4, 2010 | 10:28 AM
Fast_Freddie's Avatar
Veteran: Navy
New plugs, what are the plugs currently gapped at.
Old Mar 4, 2010 | 10:34 AM
SmurfZilla's Avatar
I'm embarrased to say I don't know. I bought the car of a tech that worked a local but very well known performance house.
I thought Evo IX's came with platinum. What is the copper equivalent?
Old Mar 4, 2010 | 10:38 AM
Veteran: Navy
No they come with Iridium, bushur sells the copper for the IXs if you wanna go that route. The plugs are different than the VIIIS. Gap the plugs to .022" before install, and if you get the iridiums do not use the cheesey gapping wheel, use feeler gauges.
Old Mar 4, 2010 | 10:41 AM
SmurfZilla's Avatar
Yeah I've heard/read horror stories about irdiums breaking when you try to adjust the gap. Can I find the OEM iridiums or their equivalent at a regular Automotive store or do I have to contact an performance shop?
A feeler gauge makes it easier to gap them (or possible)?
Old Mar 4, 2010 | 10:48 AM
RyuEvoIX's Avatar
Use factory mitsubishi plugs gapped at .024.
Veteran: Navy
NGK:
LFR7AIX - Stock Heat Range ($8.00 each sparkplugs.com), For those with local advance autos ($12.99 each)
ILFR7H - Factory Plug ($11.71 each sparkplugs.com), For those with local advance autos ($18.99 each)
R7437-8 - 1 Step Colder Racing plug ($41.52 each sparkplugs.com)
Denso:
IKH22 - Stock Heat Range ($11.95 each sparkplugs.com)
IKH24 - 1 Step Colder ($11.95 each sparkplugs.com)
IKH27 - 2 Steps Colder
For an evo 9:
We use NGK LFR6A-11. Gap to .022.
They are copper plugs.
Affordable and work great at $25 a set.
Old Mar 4, 2010 | 11:40 AM
project_skyline's Avatar
If your running e85 run the stock heat range, set the gap down till it doesn't blow out. Problem solved.
Old Mar 4, 2010 | 11:45 AM
SmurfZilla's Avatar
Thanks for the assist guys...I'll go see what plugs i can get locally.
Old Mar 4, 2010 | 11:52 AM
1slowassevo's Avatar
Also note you might also be hitting fuel cut if the plugs don't help out look it to this too..
Old Mar 4, 2010 | 05:04 PM
jos's Avatar
jos
if u are using a stock plug too at that boost the plug spark may not be strong enought to combust the mixture, u may need to upgrade the ignition system, cuz it it works fine at low boost this must b the prob
Old Mar 4, 2010 | 05:48 PM
mt057's Avatar
I am having a similar problem. I have gapped my plugs down to .022 or .020. I am running ngk bpr7es and have had to change them frequently. I am just having issues with them breaking up. I am going to try a spoolinup cop and see if that helps.
EVOlutionary
134
Apr 9, 2012 03:58 AM
GST Motorsports
Oct 4, 2011 08:47 PM
GST Motorsports
Dec 1, 2009 07:49 PM
filter
51
May 16, 2009 06:58 AM
9sec9
210
Jan 20, 2009 05:38 PM
