How to make a clutch job more difficult ....
After all was said and done, it turned out to be a problem on CCI's end (it was drop shipped from CCI, not from SBR Warehouse) ... Slowboy took very good care of me, they will have me a new clutch in under 24hrs from the problem being reported. They ate the shipping both ways on it, and i even got a call from the boss regarding the situation. The experience hasn't deterred me from using SBR ... its just made me more aware to double check things bfore starting a big *** job!!
Did my clutch job on my rs, everything was ez until putting the trans back in. Then i found out i have a bad pressure plate because it slips like a ***** and the engagement point is at the very top even after adjusting the pedal. Which means i have to do my clutch again, never again ACT.
Well ... another day gone by still no finished vehicle ... Took the tranny in and out 4 times today ... No matter WHAT we do, we cant get the clutch fork to release ( i think its release)
My best assumption is a problem with the throwout bearing or something.
Clutch fork sits in middle, has roughly 1/4" play to drivers side,
Impossible to push by hand to the pass side
install slave ... bleed... depress clutch pedal ... Slave pushes fork to pass side, it makes a loud click, and does not return....
Is there something special im supposed to be doing when putting the tranny back in?? is the clutch fork supposed to be in a certain position?? Is the lock ring not seating on the TOB .. im lost and stumped and frustrated and ready to take a plasma cutter to the car and part it out!
Did you guys double check the fork assembly to make sure you guys put it back together right? The spring is tricky but only goes back together one way. It should press from the driver side to the passenger side the first time and you're all set. I would start at the reassembly of the fork to make sure everything is right and the spring provides tension when you move the fork.
Are there any additional things off the old TOB/Pressure plate that need to go back on the new one???
Unpacked Pressure plate & disc
attached disc with alignment tool
mounted plate to flywheel
removed fork
removed old TOB
installed new TOB (from clutch kit)
replaced fork
installed tranny
done in that order
Marti
Marti over there knew it was my first time doing a clutch and made himself available to me via AIM and Phone for any misc questions i had or problems getting stuck.
halfnhalf83
31
Oct 7, 2015 08:23 PM
timmyk12
Northwest Region
22
Feb 11, 2012 12:07 PM
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
219
May 2, 2009 09:08 AM
Phalse
Jun 4, 2007 09:02 AM
Gruppe-S
Sep 10, 2005 02:11 AM
