Upgrading / Reinforcing the 6 speed
Old Jul 8, 2010, 04:03 PM
  #196
Erik@MIL.SPEC's Avatar
Originally Posted by Teal2nnr
I must not have read through your original post thero enough....I was talking about a build 5speed vs a build 6 speed. I will agree that this new gear set would (from my understanding) be stronger then OEM 5 speed gears.
Unless you treat the gears (shot peening, cryo, wpc, whatever) you are not increasing the strength of the metal. The REM reduces friction from what I understand, and does not increase strength. While "built" 5 speeds may handle higher loads better, they are still using OEM gears and Shep (from what I know) is not a fan of shot peening or cryo.
This Shep 6 speed will actually be built with stronger gears for 3, 4 and 5.
Old Jul 10, 2010, 05:39 AM
  #197
miragevo's Avatar
Originally Posted by JohnBradley
I posted it in here before, but we have seen at least 3 6 speeds shear 6th in extended pulls.
If the 6 speed already has wider 1 through 3 gears, wouldn't it make more sense to strengthen 4, 5 and 6 instead of 3, 4 and 5? I like cruising in 6th and putting the pedal to the metal so to speak!!!!
Old Jul 10, 2010, 10:52 AM
  #198
I think Shepard's goal was to increase the strength of the gears that will receive the most abuse racing....3, 4 & 5. Also, the new FD lengthens the gears and kind of addresses the issue. 6th gear is a cruising gear, not a racing gear
Old Jul 10, 2010, 11:01 AM
  #199
Jp7
Jp7's Avatar
what about taking off in 1st and 2nd?
Old Jul 10, 2010, 11:28 AM
  #200
If it's not a problem in the 5 speed, why would it be an issue in the 6th speed?
Old Jul 10, 2010, 11:31 AM
  #201
Jp7
Jp7's Avatar
Ever since I bought my car new shifting first to second was really tricky. Half of the time it felt like it grinded a tiny bit engaging into second unless I either
1 - really babied it at low rpm
or
2 - was driving rather agressive and let it rev past 3k before shifting to 2nd
Just being normally gentle and shifting into second around 2K was/is tricky. Been this way for 18K miles.
Old Jul 10, 2010, 11:38 AM
  #202
or
In my experience, that's a transmission fluid issue, not a gear issue. I switched to Castrol SynTorq LT from the OEM Super DiaQueen at 12,000 miles and haven't had 2nd gear notchiness ever since.
Old Jul 10, 2010, 11:41 AM
  #203
Jp7
Jp7's Avatar
i am using amsoil stuff - im not sure which...
Old Jul 10, 2010, 11:45 AM
  #204
Don't have any experience with the AMSoil stuff. I had no reason to use anything else after the Castrol solved my grinding/notchiness problem.
Here is more info on it if you're interested:
https://www.evolutionm.net/forums/ev...available.html
Old Jul 10, 2010, 11:57 AM
  #205
06MREvo's Avatar
I don't want to get I to a pissing match with Mr. Amsoil on here again but when I when from royal purple to Amsoil my 4th gear started grinding at high rpm up & down shifts...I hated it...I have BG fluid in there now & almost no grinding at all...much smoother...
Old Jul 12, 2010, 07:20 PM
  #206
MagicManRed's Avatar
I've been talking to shep for the past 2 years about this... 90% of what you guys mention about his test cars, power figures, runaway tester that sold his car, etc... are true
Subscribed.
It's only a short matter of time before it comes out. Last news I heard from him was that 25 are being mass produced at the moment and pricing will be released. Currently I think he's on vacation. As for a date, I have no idea. I'll keep everyone informed. I expect the same if anyone knows anything new.
-MR
Old Jul 14, 2010, 02:08 PM
  #207
churchja's Avatar
Been a couple more weeks since any real news about this... Anyone have any recent news?
Old Jul 14, 2010, 06:05 PM
  #208
Boostfiend's Avatar
I haven't had the grind problem ever and I'm still on the OEM stuff.
Old Jul 14, 2010, 10:09 PM
  #209
S14Swap240sx's Avatar
ive emailed shep about the trans a few times, he is always quick to reply. Cant wait to buy this and a twin plate
Old Jul 15, 2010, 09:12 AM
  #210
How many miles do you have on the car, what type of driving do you do, and what power are you putting out? MR correct?
Quick Reply: Upgrading / Reinforcing the 6 speed
