GSC S2 or Kelford cams for BBK Turbo powered IX?
which cams are better for the eVo IX that will be running a CBRD BBK Turbo? This is going to be a DD on stock bottom end 2.0L...with all bolt-ons...thanks...I cannot make up my mind as both cams are good...just not sure which are better for the IX...I don't want to secrifice bottom end...put want them to pull up top too...any suggestions would be recommended...
Bbk full and s2's here. Love it. I know this set up works but wouldn't mind seeing how the kelfords perform, so if u feel up to it throw em in and post up some results. If not go with what is proven to work over and over, gsc and Cbrd.
Jeff
Jeff
Have you guys dynoed any eVo IX with Kelfords on them? The only dyno graphs that I found are mostly for the eVo VIII...and overall it seems that Kelfords make more power up top...
My car is a DD so I would like the car to be reliable...no surges no problems with starting...etc...etc...I was really considering leaving the stock cams in there as you told me that you dynoed some eVo IX at 380whp with the stockers...
By any chance do you have a dyno graph with the stock cams vs GSC's 2? From our conversation it seems like I would pick up 20whp if I do cams but is that going to be under the curve or peak? I don't care for peak HP...but 20WHP under the curve throughout my RPM range would be something to really really consider...
***I was also curious if I were to keep my stock cam would the BBK turbo NOT be used to its full potential? or would the stock cam be more than enough for the BBK turbo potential?***
Let me know...as soon as I know...I have your number memorized...
Based on the last cam-test by AMS (i think), the Kelfords had a slight more power very uptop but the S2s had a better mid-range.. So I think for a better overall setup, the S2s should be the choice!!
mitsuevo803
Jan 21, 2017 06:57 PM
EVIL_EV0
11
Sep 19, 2014 05:27 AM
