BBK Full OR HTA GREEN ?!
#31
I think the bbk full has more than proven itself if your after stock spool and a solid bump up in power
Pump gas 91
403whp/330wtq
https://www.evolutionm.net/forums/ev...tephra-v7.html
413whp/334wtq
https://www.evolutionm.net/forums/ev...e-evo-9-a.html
Pump gas 93
476whp/423wtq
https://www.evolutionm.net/forums/ev...yno-chart.html
451whp/370wtq
https://www.evolutionm.net/forums/ev...370ft-lbs.html
E85
552whp/552wtq
https://www.evolutionm.net/forums/ev...-bbk-full.html
BBK dyno results thread to add to this
https://www.evolutionm.net/forums/se...ts-thread.html
Pump gas 91
403whp/330wtq
413whp/334wtq
Pump gas 93
476whp/423wtq
451whp/370wtq
E85
552whp/552wtq
#37
i did some searching for you and here is a comparison from a mutual vendor, mellon. he doesnt seem to think either turbo is that much better then the other.
https://www.evolutionm.net/forums/ev...93-octane.html
#38
heres a comparison from going evo8 turbo to bbk full for those that would like to see.. the guy asked cbrd about spool diffrence as you can see the bbk does well
#42
while i completely understand ypour point but sometimes you have to take things for what they are worth. its not everyday people pull off a hta green and put on a bbk on the same dyno, same day, etc...
just because someone changes something doesnt mean the info is useless, everything has its place and when trying to compare to items the more info the better.
jeff
#44
have to agree a ported head with upgraded valvetrain makes a huge difference lol. i was just going to do a built head with stock shorty on a red and try to hit 500 on pump as i knew i did not have a change with all stock stuff and red without meth
#45
We could go back and forth all day on the topic so I'll leave it alone. I guess I'm just more inclined to account for the variables and draw my own conclusions, like knowing about how much power a built head is worth at the given boost level and set up. (as Mellon did and shared with us) Definately not scientific or exact but it will get you close. Its a lot better then someone saying "bbk is better it rocks". Lol
Jeff
