4G64 100mm crank safe???
As the title states... I'm working on my LR2.4 and I'm still up in the air about the 100mm 4G64 crank. I'm looking for 700hp end goal and I have heard a lot of mixed feelings about the strength of the stock cranks. Some people say the crank can't hold 700hp and they break. Is that due to high rpms, launching, hp, tq etc... What is everyone feelings on the strength of the 4G64 100mm crank. I don't want to get an aftermarket crank unless I absolutely have to. Will the crank hold my power? Thanks for your replies.
Mikey
Mikey
No I didn't make a post about the crank before. I made a post about H or I beams. So if you want to be a ***** you can get the %&^# out of my thread. Thanks
Edit - Not bringing attention to my "build"... I'm like everyone else and what to make sure that I only have to build it once and without paying 8k. I think there is nothing wrong with asking for advice on a number of different things for one build. Everyone has his/her opinion and I like to hear them. If you have a valid thing to pass on to me and the rest of the evo community then please do, if not, don't stir up my thread!
Mikey
Mikey
Mauricio Evo IV (Aug 10, 2018)
My apologies i got it confused with the rod post
As a lot of you know ER will be building me a 10:1 LR2.4 starting next week. Currently I have a set of GSC 156mm H Beams that are rated to 550-600tq. I'm still on the fence about putting I beams in for the extra $300. I think getting 550tq making out my Red or future Black won't be to hard and that will be pushing the H beams... What do you just think? H beam or I beam?
I would like to stick with the H beams because they are cheaper. I think If I was building a 2.0 I would keep the H beams because I wouldn't be so worried about the tq getting that high, however I'm kinda scared of the 2.4 tq.
Mikey
Mikey
no problem. it is an extra 600 bucks though...
A few people I have spoke with. But the same number said they are solid... ![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
The thing is, usually when someone builds a motor and they lose it they don't advertise that they lost a motor nor do they post up a lot of pics. Just the nature of the community. Most people try to point fingers and say the problem was all in the build not the crank itself.
Mikey
Mikey
When given a choice between the lowest cost options, 4G64 crank vs. Eagle, one advantage the Eagle design has is it's oiling scheme is improved over the Mitsubishi cranks. On the other hand however, the ****-poor machining consistency I've seen from Eagle (as if the cheap Chinese metallurgy wasn't questionable enough) means that I would never install one out of the box, but rather take the time to check every journal for correct size and runout, check the crank for straightness, rebalance, and conduct a Rockwell hardness test as well.
1 Post
So are the cranks treated differently than the 2.0?
Im sure there are a plethora of ladies and gents on the boards running 2.3 strokers on the stocker 2.4 crank.
Im curious as well, but I wanna see the data. The 100mm crank in the 4g64 would be more reliable than in the 4g63 block because of rod angularity.
2.3 ppl please post up
