BR cast Manifold HTA35r kit or ETS Super value manifold with 35r
Old Mar 22, 2010, 10:11 AM
ETS Michael's Avatar
Originally Posted by detroit pistins
Michael,
which of the t3 pt turbos do u think will get someone around 400/400 on a mustang dyno with the following mods:
1) 3.5'' ets kit
2) 3' tbe
3) ets t3 kit
hope this question helps the op as well.
Thanks
PT5857 will do it. This will give you faster spool up then the 35R and 6262 as well
Thanks!
Michael
Old Mar 22, 2010, 10:27 AM
gsrboi80's Avatar
Big power has been made with the SV mani. DSM25psi (I think his name is) put down over 700 hp on a SV mani.
Also many have done really well with Buschurs cast option.
I personally have the SV mani on a BB 61mm and spool up is very good. and I couldn't be happier.
Old Mar 22, 2010, 06:28 PM
n2oiroc's Avatar
y?
response, spool, reliability, etc.
Old Mar 22, 2010, 06:40 PM
05ah8james's Avatar
Don't gets ETS intercooler kit. The inside turns to rust :-(
Old Mar 22, 2010, 06:47 PM
n2oiroc's Avatar
Old Mar 22, 2010, 08:07 PM
detroit pistins's Avatar
Thanks!
Michael
whats the flow rate on those and at what psi was is tested?
Thanks
interesting! need to do some more dd on my side. thanks!
ur probably reffering to the old ic piping they have sold, which i believe they have warrantied those who brought up the issue to them. i have the ets ic on and its alumium, so no rust on my end.
Old Mar 23, 2010, 05:22 AM
gsrboi80's Avatar
They did away with mild steel piping a while back. The IC's are aluminum
Old Mar 23, 2010, 06:03 AM
FL_SilverEvo8's Avatar
A 6262 on a stock block?? He said was going to be on a stock block right? Wouldn't the 6262 be kind of if'y on the stock block?
Old Mar 23, 2010, 05:59 PM
JakeTheVIII's Avatar
My ETS Super Value with 35R
Old Mar 24, 2010, 08:23 AM
Thanks
They flow 61lbs/min - The intercoolers are aluminum and the pipes are stainless steel, no rust here
Old Mar 25, 2010, 03:55 AM
MrHouse's Avatar
What do think will be the difference in lag between 5857 journal bearing and BB 35r on stock block on ETSr super value manifold. 5857 journal bearing seems to be an even cheaper option with almost same results for 28-30psi 93 octane range. What do you suggest guys? I will not be upgrading my internals in future. I can live with 450 whp if 5857 journal bearaing can do it for me with almost same lag as 35r.
Old Mar 25, 2010, 08:38 AM
n2oiroc's Avatar
get the 35r.
Old Mar 25, 2010, 09:58 AM
Spool up on the 5857 will be faster then the 35R. 450whp on a dyno jet should not be a problem for a 5857 at those boost levels. There is a dyno floating around on pump gas @ 27psi making right at 600whp on a dyno jet.
Thanks!
Michael
Old Mar 25, 2010, 11:23 AM
nikkadanny's Avatar
i have the br cast 35r and i havent had any problems with it. but you cant go wrong with either br or ets.
Old Mar 25, 2010, 12:17 PM
EvoM Moderator
scheides's Avatar
FP Black, Map Rev2 exhaust manifold, Megan SS o2 housing. Port/coat everything, reinstall heat shields, done. Stealth and fast as ****.
Quick Reply: BR cast Manifold HTA35r kit or ETS Super value manifold with 35r
