View Poll Results: GSC 2.2L Vs Buschur 2.1L 4G64 Stroker Kit
GSC 2.2L 4G64
50
44.64%
BUSCHUR 2.1L 4G64
62
55.36%
Voters: 112. You may not vote on this poll
GSC Power-Division 2.2L 4G64 Vs Buschur 2.1L Stroker Kit (Not short block)
#46
Technically, if the billet crank is lighter (assuming strength is the same or better), there's an advantage there plus the aftermarket crank could be more aerodynamic depending on design. Whether that's enough to show up in horsepower or times, that's a whole other question.
#47
He does now, because of sponsorship. Before that he had a GSC 2.2. Yes, the GSC engine saw some damage at some point, but it's not proven to be GSC's fault, and after all, it was a serious time attack car, engine's don't last forever under that use. Leading up to that, it performed extremely well. His racing proves that.
#48
GSC Billet cranks offer a 100, 88 and 94mm stroke, they have a proprietary design in the oiling passages (a tapered design to promote even flow to all bearings), they are harder to bend or flex than a forged unit, and are an all round stronger piece. Are all of these things needed to make horsepower? no, but everyone of them helps to increase reliability in a high hp engine.
#49
https://www.evolutionm.net/forums/6816024-post31.html
Can you answer that here?
#50
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
#51
BTW, sitting here thinking about this, 20gmr, since your stupid comments pissed me off. I do remember speaking to a guy, I think in N or S Caroline a few weeks ago and I'm guessing that's who you are referring to as it's the only story I know of about an engine that failed. Did he also tell you he blew a head gasket and melted off an electrode in that engine? Maybe he missed that detail. Did he also tell you that I told him in order to do anything the engine needed to get here first. I'd inspect it and determine what was the cause and even if I did determine it was nothing on our end I'd fix it for my absolute dead cost of parts and machine work because he did buy it from us and I appreciated his business?
#52
Both, if you look at their stroker kit online, it shows 86.5mm and the 87mm bore for the 4g64. See link below: The website was just updated!
http://www.power-division.com/home.php?cat=271
#53
Greg, I never saw your reply to this question when it was posed to you a while back:
#54
#55
Greg, what trade offs are there when switching from a 4G63 block to a 4G64 block?
David, feel free to answer this too, the more info people have the better they'll be in making their decisions, thanks
#56
Hey hey now, you are putting words in my mouth
I have no idea how long he had that motor, but from his vids on youtube it does look like he got some good use out of it
The point I am trying to make is, whether you decided to build an AMS 2.3, Buschur 2.3, GSC 2.2... or what I would recommend, a bit pricey at that, a Cosworth 2.2, you will be getting a quality product
#57
Cosworth is too much $$$, Buschur or GSC. I need to make up my mind if I ever plan on going bigger the the FP Black or not. If not, I will go with the GSC, if so, It's buschur.
#59
eric@milspec, thanks Capt. Obvious.......rods packed in plastic cases are better too if you drop them before you install them they aren't as likely to get damaged.
Advantages between the blocks are debatable. The 2.4 block is a hell of a lot cheaper and that is one of if not the biggest advantage. It is also less likely to crack at high HP levels but there are very few guys cracking the 2 liter block anyway and even less running in the danger zone of having it happen. The 2 liter has a better head seal than the 2.4 block the 2 liter block is also lighter. No extra work has to be done to put a 2 liter back in your EVO, the 2.4 block requires some minor adjustments.
Let me also add that while I'd love to sell ALMOST anyone one of our engines it is surely not worth me argueing over. I have nothing negative to say about other vendors mentioned in here mostly because I don't care. I don't know how many engines we've sold, it's a rediculous number. I don't know if I need any more engine business (although I'll take it) as we can't build them fast enough as it is. You RARELY see/hear or experience one of our engines failing and I know how many we sell, that's good enough for me. It's like double pumpers, we did it first, other followed but in reality we shipped 15 of them last week and are shipping 7 more this week. I know and so do most others what products are good and proven and we prove what we sell on a daily basis. I don't need to trash talk and get in pissing matches over what works and what doesn't. Unlike many, I've proven what works.
Make your choice, buy an engine, from me or someone else, it won't hurt my feelings and I hope whatever any of you chose works out well.
