Pressure leaking out of oil cap?
So Mellon Tuning is saying that you need to plug the breather from VC to intake and Evoryder is saying let it vent???
Which is correct?
I also had pressure escape from my oil cap and a good amount of pressure venting from the breather on the drivers side. I also attached a hose to direct the hiss coming from the valve cover/intake line.
I'm performing the test with the tester connected directly to the turbo inlet. MBC/compressor line plugged. PVC/valve cover still attached. Valve cover/intake line venting
Is this correct?
I am able to get 23psi ( I run 23psi) but it's leaking from the oil cap and slowly bleeds off...
Also, will running big cams affect the ability to hold pressure?
Which is correct?
Is this correct?
Which is correct?
Is this correct?
Which is correct?
Is this correct?
Let the valve cover vent. To minimize the amount of air that escapes from the valve cover area:
1. Do the boost test with the engine at normal operating temperature, as this helps minimize the blow-by at the piston rings.
2. Make sure your PVC valve is working and therefore not letting pressure from your intake manifold to enter the valve cover area.
3. Get the engine close to TDC by slowly rotating the crankshaft pulley clockwise until leakage from the valve cover area is minimized.
Big, aggressive cams can increase the valve overlap and therefore they will increase the amount of leakage that you see at the valve cover area.
Dan (drb)
Sweet thanks man....I'm picking up a new pcv tomorrow. I know the engine is good...compression is right on. Just kinda freaked me out that the oil cap was leaking so much pressure. I think all thefactors....big cams, cold engine, not necessarily at TDC, pcv.... added up to pressure in the VC. I don't think the oil cap is meant to see any real pressure...I have a nice HKS cap and everything seems good with that
I do seem to be burning a little bit of oil ever since i installed the cams though. I have still yet to decided weather that is form my valve seals leaking or just from excessive blow by as i do have small traces of oil in my charge piping (no catch can). Compression test returned good results and far within spec. 80k stock bottom end.
Good luck with everything
Ethan
I recently replaced my pcv valve with one from napa and noticed the same thing during my boost leak test. I assume the pcv valve should not let any positive pressure from the intake manifold to the valve cover?
Before you install it, put the valve to you mouth and blow through it. The valve should only allow air through one way. If NAPA is selling a PCV valve that doesn't work this way it is the wrong valve. Take it back.
Pcv(positive crankcase ventilation) is meant to allow air in the valve cover to recirculate back to the intake... And not the other way around. So I would double check the napa pcv
SILVER SURFER
241
May 5, 2011 07:25 PM
deathtracks
Sep 27, 2010 07:00 AM
ball7068
14
Jul 28, 2010 08:44 AM
