I *think* it's the TC death whine, but want to be sure before replacing it.
Ok. I have a 2006 IX MR with about 6k miles on it. However, it has been in an accident before, so it's possible that something was damamged. After the car was fixed, it drove for around 2000 miles without any TC noises.
NOW, kind of suddenly, I am getting a whining that sounds very much like all of the videos out there of TC death whine. Pitch goes up as speed goes up, regardless of gear, etc.
HOWEVER- If I coast, either by pushing in the clutch, or just letting off the gas while in gear, the noise completely goes away. From what I have read, usually the TC will stay noisy even when coasting.
I changed the TC and rear dif fluid and the sound remains. There were not a lot of shavings on either plug.
I've accepted the fact that I probably need to change the TC out, but want to make darn sure that's the problem before I do...
Also, is there anything that could cause that failure that I should check before installing a new one? Seems odd for a 6k mile box to go, although I do not know how the car was treated before the wreck. Would an axle alignment issue maybe cause it to prematurely wear?
Thanks for any advice.
Robb
Robb
Having the same problem and was about to post this as well, noise increases with speed, and goes away with the clutch pushed in. 45k miles on mine though. I'm taking it to a shop tomorrow, I'll let you know if they say it's death-whine or not.
I had a similar issue. I thought it was my TC and after further investigation I am pretty sure its my Throw out Bearing making noise. I get a whine and as soon as i push in the clutch no noise. I also get a bit of noise at idle. I pulled the inspection plug and looked and I see the TOB rattling around so I am chalking it up to that..
Robb
Robb
It sounds just like the other clips online, except that it disappears when I step on the clutch. Fairly certain now that is the problem. Either way, I found a used TC that is going to Shep for a stage 2 or stage 3 upgrade.... hopefully the sound will be gone once I put that in!
owexonline
Outlander Sport
14
Nov 17, 2021 02:20 PM
SyncdLancer
Sep 29, 2016 04:39 PM
evovin
20
Nov 9, 2007 08:15 PM
