engine over heating
Old Apr 6, 2010 | 06:47 AM
gsrboi80's Avatar
I'd start with your fluid level and themostat first. Fan shouldn't be your issue as you were on the highway at 80 mph speeds when it started to get hot. But you can make sure they come on. My guess is a coolant flow issue or insufficient coolant level
Hell I haven't run an inner fan in almost 2 years now with absolutely no ill effect. Car temp needle never even gets to the middle.
Old Apr 6, 2010 | 02:39 PM
gqcode's Avatar
Veteran: Air Force
just went got a thermostat the one they sold me way to small and the old one is open at all time and won't close put hot water and cold and it stay open could that be the problem !!! I will other a good thermostat online since autozone fail me baldly!!!
Old Apr 6, 2010 | 04:11 PM
gqcode's Avatar
Veteran: Air Force
Talking
To All I want to say thanx !!! I'm boost happy ! Put the new thermostat from autozone made a little mistake during the install. I'm happy that i find it b4 i returned the part. The car is running good the temp is ok in stop and go traffic but on the highway when hitting *** mph the temp is way low i mean close to the C. When i came off the highway my idle was like if the car was warming up as the temp when up the idle when down. Other than that happy no head gasket to deal with!!!
Old Apr 6, 2010 | 07:03 PM
barneyb's Avatar
Are you sure you didn't put the old one back in?
Old Apr 6, 2010 | 07:27 PM
turbotalawd's Avatar
[quote=barneyb;8172890]Are you sure you didn't put the old one back in?[/quote
Old Apr 7, 2010 | 12:19 AM
gqcode's Avatar
Veteran: Air Force
yeah the old one look different then the one i got from autozone!!!
Uryelowducky
Pacific Northwest
17
Sep 24, 2013 12:03 PM
TeachersEvo
Jul 31, 2012 07:54 AM
brand0n
May 1, 2011 04:19 PM
Gordian79
Jun 25, 2009 06:24 AM
naucrx
25
Jun 28, 2007 03:11 PM
