BISS screw adjustment
How many miles on the BISS screw do you see that kind of corrosion>?
Also, how do you activate SAS mode in evoscan? just bought it the other day and am a little confused about SAS. I'm looking for the internet how-to right now, just hoping someone could help me with a link or a quick answer. thanks!
i did find this interesting faq on evoscan about a galant owner having issues...i don't have all the equipment to perform the troubleshooting, but it does make me want to reset the ecu with ecuflash to the stock software and adjust the BISS screw from there....
http://autorepair.about.com/library/faqs/bl620g.htm
http://www.dsmtuners.com/forums/newb...ne-use-10.html
also read this which makes me a bit nervous... http://www.30-130.com/showthread.php?t=213916
I am having this issue right now but it only started after I replaced my timing belt. Maybe my car was tuned when my timing was a little off. Thinking about adjusting the biss screw. Where can I buy the tactrix cable?
RelentlessEVO
Feb 27, 2017 10:02 AM
audiofan
Aug 14, 2016 08:47 PM
adjust, adjusting, adjustment, biss, body, car, evo, evolutionm, idle, location, mitsubishi, sas, screw, set, throttle
