Head porting
Head porting
So I'm thinking about having my Head ported, but just gasket match the ports. Will this have any benefits, if so what would they be?
I did try searching but the only posts I found were with valve work and other work done. I'm looking for info on just having the intake and exhaust ports (correct me if this is the wrong termnology) ported out.
How tough is that? Could my local engine shop do that, or would I need a specialist. I was just looking for a quick upgrade while my head was off.
Yeah, the bowls are good to get ported. I think your talking about having the combustion chambers ported.
Doing this should lower your compression and torque a bit as well. I contemplated for a long time getting it done, but unless your going for numbers in excess of 600hp, I don't think it is worth it.
Oh and my end goal is only like 400 to 450whp. I know I dont need head work at all to hit that but I figured while its off I might as well, it can only help
IMO the port cross sectional area is plenty large... I wouldn't gasket match it will kill port velocity.
The casting of the head does not agree 100% with how it was machined... you're essentially "lining up" the ports with the valves and removing any casting errors from the factory. A very simple procedure that will make your head more efficient with no ill effects.
10isace
11
Jul 18, 2012 01:48 PM
SmurfZilla
Jan 21, 2011 08:57 PM
