Evo 9 Valve adjustment??
Well, being that your manifold will heat up very fast, if there is a small leak on one of the runners, the noise will go down or away after the manifold expands. I'm being serious, check the manifold. It sounds like it's in synch with one cylinder........If that's not it, we'll go from there.
ok update of the fix..
The guy i bought my car from has left me tons of suprises and found more to add to the list..
He was missing (2)12's on the lower part of the manifold, and the right side 14 inch nut was finger loose :| Tighted it up added 2 nuts and BOOM the tick and leak is GONE :P Thanks guys. just needed a day off of work to put a little TLC into it.
Awesome you found it! Bumble bee sound is normally always exh. leak...... When the motor is dead cold, if you turn it on and run your hands around all the joints you will find the leaks... that is what I've been doing for years........ (careful that mani gets hot quick, but you should have ~40 sec... plenty of time
SaulHudson
Nov 22, 2011 12:01 AM
mxguy1286
Jan 26, 2011 03:53 PM
Impulsoren
Feb 6, 2007 08:59 AM
