Samco Intake Hose Fitment
How is the fitment with the Samco Intake Hose? I am about to install one and it looks like it will make the filter hit the intercooler spray canister. Have anyone tried this intake on an Evo 8 with the stock intercooler canister in place? This only applies to 03-04 Evo's. I think the filter is a vibrant filter.
The great thing about the Samco is that you can trim it to fit most filters. I know my friend trimmed about 1" off for it to fit his IX with an Amsoil filter.
While you're at it, rethink your choice of filter: https://www.evolutionm.net/forums/ev...t-results.html
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Incidentally, which end of the SAMCO intake hose should be trimmed? Can one trim the end that connects to the compressor inlet or only the end that connects to the outlet side of the MAF sensor? Or both, or either?
I was checking some images and the stock hose and the Samco appears to be about same length. So how about using a filter on the stock hose. Same trimming issues? The advantage of a slightly longer hose is that the filter will be farterh from the heat and radiator fan air.
That means that the Perrin is slightly shorter than the stock one? I'll check if the stock airbox fit with the Samco.
Just to make a quick test I install the Intake Hose with the MAF adapter but no filter. Did two 3rd gear pulls and compare logs to the one with the hacked box and stock intake hose. Using VDR I got basically identical results for the two setups. On the second run I got massive knock (about 20~30 counts from 6K up)
Airflow did increase from 40.5 lb/min to 43.3 lb/min so the there is a restriction on the stock intake but for some reason power was the same. I did no change in the tune just change the intake hose and removed the filter. Does these results makes sense. AFR were about the same for the run at about 11.3 AFR on 93.
The hose doesn't HAVE to be trimmed but almost all open air filters will fit better with it trimmed. I know on mine if it wasn't trimmed the filter jiggles around resting on the airbox mount and when the car is driven aggressively shock to the MAF causes the car to stumble.
Now I'm sure there are ways to prevent that from happening but trimming the Samco hose is the least "half arsed" way of doing it.
^ 100% true. I made the same choice. Trimming it also allows you to hack the stock airbox and use a conical filter inside the factory box.
Here is the link to my FS thread. I am flexible on price if anyone wants to bargain.
https://www.evolutionm.net/forums/sa...ose-cheap.html
FS[Northeast]: Evo 8/9 Evap Canister (42k miles)
yellowevo82
Jan 27, 2017 03:36 AM
FS[Northeast]: NY: Samco intake/ K&N, Hallman PRO MBC, Evo IX BOV, Blox roll stop, Ashtray gauge POD
MisUnderStood
19
Sep 15, 2015 05:30 AM
12WWGSR91
10
Apr 11, 2015 09:36 AM
JKav
Oct 9, 2014 07:48 PM
