Transfer Case after Trackday
![Unhappy](https://www.evolutionm.net/forums/images/icons/icon9.gif)
Let's start at the beginning. I own a 2003 USDM Evo 8, stage 1 mods. Done 97.000miles
Car has had all the fluids changed within the last 2000miles.
All the fluids looked good at that time. Cusco oil used in the 5spd gearbox, (non-acd) transfercase and RS diff.
No strange noises, besides a very slight whine when "braking" on the engine/driveline. But nothing to worry about really.
During the trackday yesterday I thought to hear a whine, but when going full throttle you don't notice much other noises besides the engine/exhaust offcourse. On the way home I heard a speed dependant noise which got loud from 20mph and unbearable until 90, then it got quieter. Still drove home easily, for 100 miles. The noise was only there when accererating, also when only slightly accererating...
Tonight I listened with a stethoscope onder the car on a 2pillar ramp, RS diff was really quiet, gearbox made some noise around the startermotor but the Transferbox was whinig like I never heard before, just hurts your ears.
Drained the T-case oil and this is what I found:
crownwheel and pinion look damaged, silver flakes in the oil and a lot of very small metal pieces on the drain plug.
Oil that came out is ~0,55 litres so low on oil wont be a cause I believe... ?
What is the cause?
how can it be prevented?
Thanks for your help![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Pictures:
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/9176793843.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/2689615043.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/9481703135.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/8934775567.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/3252759280.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/5900391092.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/8030280033.jpg)
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/9304580546.jpg)
What is the cause?
Pictures:
![](http://www.vleegtuug.nl/upload/files/vleegtuug.nl/album/6558437990.jpg)
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
The oil was black with little pieces of metal, also it smelled burned (stinky indeed).
0,55l came out so that is about 0.6qt IIRC
Had contact with shephard transmissions and John said, whatever oil was in there... that's the cause of the failure.
It was Cusco transmission oil, recommended to me by a company who specialises in Japanese cars. ![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
Yeah, looks like you used the wrong oil in the Transfer Case bro. I don't suggest you run the DiaQueen either, if this is a car that sees frequent track days. Once you get it rebuilt, run Redline Heavy Shockproof or similar in the TC.
Also, drain the rear diff as it looks like you're using the wrong gear oil in it as well. You want to use a good 75w-90 in the rear diff. you can use Redline Heavy Shockproof in the rear diff as well, but will need to add a friction modifier for use in the LSD rear. I suggest using Redline 75w-90 in the rear.
Sorry about your luck man. GL with everything!
For you other guys out there suggesting OEM fluids, stop. This car clearly sees the track. The OEM fluids were not meant to stand up to the rigors or frequent track use or high horsepower.
And if i were you guys, i would drain the OEM fluids strait away. GO with Redline or Amsoil products rated for the proper driveline parts.
Here is what i use:
Tranny: Redline MT-90 or a MT-90 cocktail(i personally use MT-90 strait)
TC: Redline Heavy ShockProof(you can also use Light ShockProof)
Rear Diff: Redline 75w90(you can also use the shockproof's i listed above, but will need to use a friction modifier. You can get away with not using the friction modifier, but the rear diff will be a little noisey)
Amsoil also makes great products...i would use either of the two....
I will say this though, OEM DiaQueen would of been better than the stuff the OP was using. At least DiaQueen was rated to be used in the TC.
Here is what i use:
