Advice Needed: Engine Removal
#31
Maxjax
Yes, it is very nice quality, built in Germany. Just 5 inserts in the floor each side and I have had my Range Rover up on it so I can vouch for the strength and stability !
http://www.youtube.com/watch?v=QSUAXQOoXuY
http://www.youtube.com/watch?v=7kXzzrufv_M
#34
So I'm planning on hopefully removing my engine today (or over the next week) and I've got a rpetty firm grasp on things, but I did have a couple small questions. This thread was pretty helpful so I thought I'd just bump this instead of creating a new one to help out future searchers.
The only part I'm unsure about is kinda dub: it's about what fluids I'll need to drain. Obviously the motor/trans/acd/coolant will get drained, but I'm unsure about the power steering fluid and the brake fluid as well as the A/C freon (technically it's a fluid...) I guess that even if I don't have to I may as well replace them, but I'd just like to know for sure. For the freon, do I just open up a valve somewhere and it vents out? Or is it possible to remove the A/C system without having to lose the freon. (by freon I really mean R134a)
Also, what should I do with the coolant/steering/brake fluid? Should I mix it with the oil and bring it to a car shop like normal or put them in a separate container and bring that?
#35
the AC gas should be vacuumed out..
the steering pump oil is just plain ATF, so just mix it with engine oil and dispose properly.
#36
having said that, you can always remove the AC compressor from the engine an leave it hanging in the engine bay... remove the engine without it..
antics22
Evo X How Tos / Installations
267
Dec 6, 2016 08:40 AM
wannagofastt
Southeast Region
Mar 8, 2016 10:51 AM
LOWPROaero
41
May 20, 2013 12:01 PM
