are there any aftermarket snorkel replacements for evo 8 & 9
Old Apr 23, 2010, 04:42 PM
racer135's Avatar
Originally Posted by 03whitegsr
http://www.nengun.com/monster/intake-duct
I've got a knock off of one of these ("long" style that has a scope infront of the radiator) sitting around. If you are interested, PM me.
I belive you have to cut the hood to make this fit on an 8 or 9. They are made for the Evo 7, right?
Old Apr 23, 2010, 04:50 PM
FJF
FJF's Avatar
Originally Posted by racer135
There is plenty of info in here. You need to modify the airbox lid or the airbox side to increase the airflow. I did some tesing with an open filter and went back to the modified stock box. It was done with VDR.
Fair enough. Where does the snorkel, itself, come in?
At my power level 350 awhp there is not a big difference.
Right.
Old Apr 23, 2010, 05:24 PM
240Z TwinTurbo's Avatar
Snorkle is the main restriction of the stock intake box. I have tried to look for an aftermaket bbox cover with snorkle with no luck. Ended up modifying my stock airbox lid.
And yes the snorkle is the main restriction of the stock intake box.
The overall restriction for making power with the stock air box is the filter element. Look up the part number from K&N and call them to get the CFM rating. What you will find is the flow is rated at under 500cfm so the filter is really only designed for ~325hp @ flywheel. Yes you can make more power, but with a higher pressure drop across the filter.
Whatever power level you want to make, multiply that by 1.5 and that is how much CFM your filter needs to provide. The ARC box is a good substitute and I recently purchased one as a baseline to create my own. I am in the process of making my own box using two K&N filters that flow a total of ~900cfm.
With the stock box and K&N in the boost would taper from 21psi to ~19psi. With the ARC box the boost holds 21psi to redline. This lets me know the stock box/filter is a big restriction.
Old Apr 23, 2010, 05:42 PM
ch53avitech's Avatar
I still don't see the point of doing all of this. Just get a proven Buschur, AMS, ETS, HKS, or alike intake system.
Old Apr 24, 2010, 10:05 AM
Another quick note. I let a buddy of mine borrow the ARC box to do some logs. With no other change other than swapping the stock box/K&N filter to the ARC jobber the AFR's went from 10.8:1 to 11.5:1. This was 21psi.
Old Apr 24, 2010, 05:59 PM
racer135's Avatar
A couple of months ago I went to the dyno and did 2 pulls to compare, one with the airbox with a Works Filter, modified airbox lid and the snorkle in place. Then did a back to back pull with no airbox lid and no filter. The peak difference was 5 awhp. There were places when I saw maybe 8 awhp diff along the powerband. Same tune, same boost a little leaner without the filter and lid. Maybe with some tuning I may get a lil more.
I am tempted to test the Perrin but it is a $250 test. For now I think I will modify the airbox side and I already have the lid modified and the WORKS filter. I need to save $$ for a BBK or an HTA Green.
Old Apr 24, 2010, 06:53 PM
Whether you see more significant gains will really depend on the hp levels of the vehicle you are testing. If your test was for a car in the 300hp@wheels range then differences may be small as you noticed. If you are testing in the 400hp@wheels range then the difference may be larger. What HP level where these tests based?
Another bonus of the ARC box is the custom cast velocity stack inside the box.
Old Apr 24, 2010, 09:42 PM
racer135's Avatar
Car puts 350 awhp at 23psi. ARC box looks like a nice piece but it is too much money for what it is.
Old Apr 25, 2010, 06:46 AM
Indeed, which is why you need to find one used for ~$225.
krypt952
Apr 13, 2016 06:23 PM
hydro334
Apr 2, 2016 11:22 AM
Luckystryke
Feb 27, 2016 09:39 AM
CaptainAsia
Jun 1, 2011 12:14 PM
vplukas101
43
Jun 4, 2010 05:03 PM
Quick Reply: are there any aftermarket snorkel replacements for evo 8 & 9
