1600cc, Single Walbro?
Old Apr 28, 2010, 08:26 AM
Domolution's Avatar
Originally Posted by buchnerj
e-85 most likely, but still 1600cc for an old school green and no built motors is overkill.
+1
Old Apr 29, 2010, 06:34 AM
TurbosamVIII's Avatar
Why not go with meth injection?
Old Apr 29, 2010, 06:45 AM
buchnerj's Avatar
E-85 is a safer option, and MUCH better for the motor. Meth is extremely costic and terrible if not used properly. Also, you have to constantly fill up the meth tank, have a failsafe that you feel confident in, otherwise you will run extremely lean and blow the motor.
E-85 is cleaner burning, cheaper than 93 octane, and becoming more readily available over the majority of the U.S.
Old Apr 29, 2010, 08:27 AM
FLASH1970's Avatar
Bigger is not always better. Get some smaller injectors. They'll be easier to dial in.
Old Apr 29, 2010, 08:49 AM
buchnerj's Avatar
This is not necessarily true, as Ted B and I described earlier. The problem is the old style Bosch injectors, they can't idle correctly with that small of a demand for 93 octane. You can get new style injectors all the way up to 2000 now that idle like stock injectors. The problem isn't the size, its the type and how well they handle the small amount of fuel needed for his goals.
93HardTopTurbo
Nov 21, 2022 01:04 AM
mydnyte93
Aug 3, 2016 10:09 PM
dj0521
Lancer Aftermarket Forced Induction Tech
17
May 15, 2006 04:05 PM
93civEJ1
17
Sep 7, 2004 12:54 PM
93civEJ1
Aug 15, 2003 11:02 PM
Quick Reply: 1600cc, Single Walbro?
