Autronic PnP Evo VIII Board
In Timeout
100%IDC is STUPID and asking for trouble. Over 90% they start having problems. You are right most DSM's just have to be fast for 1320. I would hate to see them with a 2 hour lapping at a track, 99% would be blown up on the side of the road.
Originally posted by MP5
See I think I finally figured this out DSMers dont want a fast car with the right components on it all the time. They want a "capable car" One that is normal day to day but then lean it out to 12.4 to 1 on c-16 and 100% IDC after all its just gotta hold together for 1320 feet. I dont get it I want a car that is in the same state of tune for daily running the friends and track days (100 ) octane to be safe of course but I dont get it not till I bought a mitsu did anyone I knew avoided 100% IDC at all costs
Originally posted by 5StarSuzuki
For some strange reason...I get the feeling...
THEY KNOW WHAT THEIR DOING.
You don't race your car for "safety" for you or your car.
...I guess its fun to milk the last drop out of it once a week at the track then limp around town in normal tune...
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
![OMG!](https://www.evolutionm.net/forums/images/smilies/SHOCKED.gif)
![Devil](https://www.evolutionm.net/forums/images/smilies/devillook.gif)
In Timeout
Thats the point of going to the track! The pavement is perfect, conditions controlled. One of the advantages of having an AWD, is that on the street an 11 second Mustang(with slicks) is a 13 second car.
We obviously know that 100% IDC is not safe.
I drive this car everyday and hence, we are building our whole fuel system for it plus a new turbo kit, intercooler etc. We have had a set of 1000cc injectors, fuel rail, fpr, pump, sitting here but we wanted a baseline starting point.
The point was, to get some ET times before we did all these modifications. So, next we will post our results with all these upgrades. Very simple.
Sorry if I misunderstood you.
Either way, if anybody happens to be in the KY region and would like to come check out our 20,000sq. ft. facility, we are having a couple of Evo's over this Friday, 14th and a bunch of WRX's on Thurs. 20th on our dyno. Thanks.
Originally posted by ak1
http://www.dsmtimes.org/evo.htm
7th with pretty much stock components.
Correct, we use C16 at the strip. In fact, we are distributors of VP Racing Fuels so we don't ever leave for the track without tons of C16.
However, do understand that we are still only running 21 psi and an A/F ratio of 12.1-12.4 on our Motec Lambda meter. On boost it has never gone higher than 12.4 at 21 psi. Injector duty cycle is maxed out at 95-100%.
We are not stopping here, it was just a test to prove that tuning was key in getting those ET's. This month, we will be putting on our T3/T4 turbo kit, bigger intercooler & piping, fuel system, internals and we are shooting for low 11's without nitrous.
We have 3 basic maps developed for the Evo VIII,
(WHP numbers taken on our Mustang-500-AWD Dynamometer)our stock map took our stock Evo from 206whp to 248whp with just tuning and keeping everything including boost, timing and A/F ratios very safe. This is on pump gas.
Stay posted for new dyno numbers and track times (if it doesn't get too cold
) once we get our turbo, fuel system, internals, etc.
Drive safely!
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Drive safely!
Everytime I hit any turn signal or other electrical device I get a sync code and it goes into limp mode
Any thoughts?
Originally posted by Alfriedesq
can you guys help me with the battery voltage / misfire problem I am having - my board only reads 10.02 volts - even though my car has 12.4 volts at the ecu harness
Any thoughts?
Any thoughts?
Ken
Originally posted by Illrunya
Interesting, I need to check out my voltage. I am getting a continuous misfiring code(00304) even with new coilpacks from the dealer, and a swapping for fresh plugs.
Ken
Ken
Ken
Ken
When you get that code does the car go into a limp mode of some sort till you turn it off and restart it ?
Ken
Ken
Very odd, I have not seen any of these problems before, but I will do this tomorrow; I will check with Steve @ Aussie Imports to see if he or Ray Hall have similar issues.
I believe he could still be in FL. Either way, I have always had excellent tech. support and help from Steve so I'm sure he will handle this appropriately. Thanks.
Oh and I've added some video files of the Evo runs and our 9.55 second Conquest running Autronic as well (Drag Racing Forum). Our 1G GSX with Autronic runs 10's as well but he broke it on the run against me unfortunately.
ONLY issues I have left is the battery voltage issue and hooking up my motec wideband so i can log on the board - did you do that with yours ?
