Mikey's LR2.4 MIVEC 10:1 Motor Build
#482
Some of the 5k dip is getting the cams to work with the MIVEC map. I moved it around a little and got the dip better but some of it is also actual ignition timing. I dont normally release break in tune stuff (other than mine) but Mikey needed some results shown so rough or not here it is
#484
Mikey
#485
There is def more adjustments that will be made. The MIVEC/Timing will all have to be redone anyway once my new cams get installed, not to mention playing with the exhaust cam a bit and see what happens.
Mikey
#487
Video is not that great. Thomas had an actually camcorder and will be putting the vid up later. This is a crappy cam video. However, the turbo sounds so sick. The whine is louder than the Red and you can hear the turbo just cruising down the interstate.
http://www.youtube.com/watch?v=f7YNQIvFt0I
#489
#492
#494
Mikey
#495
