Mikey's LR2.4 MIVEC 10:1 Motor Build
#496
[quote=Svendiesel;8392191]Second that! Thats the reason why I sent the Red back that I had to exchange it for a Black when I decided on doing the 2.4
Half-assing is not an option.[/quote]
No ****. I'm the same way. I don't half *** do anything, you can tell that by looking at my build thread. Ya I was thinking about keeping the Red but I'm glad I didn't because the Red would have been way to small on the 2.4L.
Mikey
Mikey
#502
Mikey
#503
I'm glad you are going Black! You will love it. The turbo also sounds like a semi when it spools or part throttle Ya a 600-650 hp car can prob beat a liter bike. I know at the 535 level that I had with the Red I could beat 750s but the liter bikes tore me a new one...
Well I think my 2.4 Black will make 100hp more than your 2.3 Red. You should have went Black. It will only spool 200rpms later than the Red but give you a lot more power.
Mikey
Mikey
I have no dilusions about my car. Itll be fast but eventually not fast enough, no matter how much power its making.
So going from 330whp on a dyno jet to 500whp on a mustang is a good enough jump for me for now.
Besides it's an Autocross DD setup and I think Ill be a little to whilly with the current power rating already
#506
Mikey
#507
7500 right now. There is not much of a reason to go past that. The car isn't making the power it should be. Once the new cams show up and the housing gets some port work I think it will hold out the top at least another 500-750rpms longer and then I will take it to 8200 most likely. Really just all depends on the graph. If for some reason it makes power to 8500 then that is where she will spin too.
Mikey
Mikey
#508
btw to Broham here is a good built motor deal
https://www.evolutionm.net/forums/sa...et-3500-a.html
#509
#510
you could not upgrade to the lr2.4??? i know somebody that is getting a lr2.4 from them
