Kiggly HLA Pressure regulator, worth doing?
Old Mar 13, 2012, 06:16 PM
  #91
kyoo's Avatar
just ordered mine
Old Apr 19, 2012, 09:00 PM
  #92
eric6's Avatar
So does this help lifter tick?
Old Apr 19, 2012, 10:37 PM
  #93
Thore's Avatar
$50 more and you can get GSC Zero tick lifters.
Old Apr 20, 2012, 02:16 PM
  #94
Broham's Avatar
Damn Kiggly posted. There is 0 risk with this part. If anything, it's better than oem and will help jb turbos have better oil access from assuring more is in the pan. Great part
Old Apr 25, 2012, 01:34 PM
  #95
foxbear2277's Avatar
<p>
Originally Posted by kiggly
My regulator will not alter the oil flow or pressure to the lifters compared to OEM at warm oil idle in any way, shape, or form. The regulator only begins altering pressure to the lifters when the supply to the cylinder head oil gallery exceeds 15psi. This is not the case in a low idle with warm oil. Whomever recommended it wasn't appropriate for engines idling below 1200rpm must not understand how it functions. It does not regulate or restrict oil flow to the lifters until there is already an excess. We have plenty of regulators out there with low-idling engines and no issues whatsoever.</p>
<p>&nbsp;</p>
<p>The stroker motors actually have worse windage at the same rpm compared to standard crank motors because the rod big ends are swinging at a higher velocity. The HLA regulator delivers increasing improvements with both higher rpm and increased blowby. Something like a bone stock engine that seals up great and is only used to low rpm may not see a significant change. But as you push it harder, the improvements will increase.</p>
<p>&nbsp;</p>
<p>I'm sure there are plenty of people out there who can chime in that even in 3XXwhp sub-8000rpm setups they saw less oil in the catch can after installing our regulator. For everyone that has seen this, it is direct evidence of more oil remaining in the oil pan during heavy usage. Less oil in the catch can is the result of less oil suspended in the head and valve cover to be pushed into the catch can due to blowby. The only other place that oil could be is down in the crankcase and oil pan.</p>
<p>&nbsp;</p>
<p>Thanks for reading,</p>
<p>Kevin
</p>
<p>&nbsp;</p>
You simply have me sold
Thanks for the information!!
Old Apr 25, 2012, 07:53 PM
  #96
2006GSR's Avatar
Waiting for mines to arrive any day now.
Old Apr 26, 2012, 10:25 PM
  #97
Levar's Avatar
I purchased mine today from MAPerformance.
Old Apr 27, 2012, 04:57 PM
  #98
eric6's Avatar
I'm sold as well, buying one shortly.
Old Apr 27, 2012, 10:28 PM
  #99
Mikey@Spec-Ops's Avatar
Originally Posted by Boltz.
I opted not to get this piece. I was in the market and was dissuaded from purchasing it. Partly because I am running a stroker motor. This coming from someone who has a ton of experience with heads and evo heads in general. The bottom line was that it wasn't good for cars idling under 1200 rpm and not necessary for cars not revving to 9000 or over.
My .02
Boltz, you should have known better brother. All the data and supporting info is in this thread. Did you even read it before making your post? I run the hla on ever motor we build. I recommend Kevin's magic piece of steal any day to anyone no matter what type of driving you do. It helps your car in every aspect bro.
Mikey
Old Apr 27, 2012, 10:37 PM
  #100
kyoo's Avatar
Originally Posted by kyoo
just ordered mine
fyi, mine's in and installed. don't even notice it's there, and i'm not tuned or anything yet. idle aroudn 900-1000
Old Apr 28, 2012, 12:13 PM
  #101
way2qik's Avatar
Installed mine today. Simple as pie. Good instructions. Quality piece.
Attached Thumbnails Kiggly HLA Pressure regulator, worth doing?-img_0307.jpg   Kiggly HLA Pressure regulator, worth doing?-img_0308.jpg   Kiggly HLA Pressure regulator, worth doing?-img_0310.jpg   Kiggly HLA Pressure regulator, worth doing?-img_0309.jpg
Old May 11, 2012, 07:20 AM
  #102
05whiteRS's Avatar
by the look of your install, does it not require removal of anything other than the valve cover? ie a camshaft or end cap. The install process seems too easy to be true.
Old May 11, 2012, 07:30 AM
  #103
MitsuJoe's Avatar
This is correct. Remove the valve cover, unbolt the old HLA, and bolt up the new one. All 10mm bolts - easy!
Old May 11, 2012, 08:37 AM
  #104
05whiteRS's Avatar
that's great, I'll definitely be adding it to my shopping list.
Old May 11, 2012, 11:34 AM
  #105
Levar's Avatar
I am adding mine this weekend.
Quick Reply: Kiggly HLA Pressure regulator, worth doing?
