coolant temp goes from 192 to 206....why?
Old May 25, 2010, 12:32 AM
  #31
turbotalawd's Avatar
My apologies. I was going off your info on your other thread in which you stated that you smelled coolant coming from your exhaust. It appears to be just a tuning issue. Good luck.
Old May 25, 2010, 07:14 AM
  #32
evo4life400's Avatar
idk if i smelled coolant haha...i was just freaking out and probably put it in my head....i need a professional to look at the car because i suck at diagnosing things
Old May 25, 2010, 08:43 AM
  #33
iTune's Avatar
Wait, i thought your tuner was looking at it? I stopped trying to help when you told me the tuner was looking at it.
I will go on the record and say, i never believed it was your head gasket. The symptoms you're giving me point to a bad tune. Your Datalogs also point to a bad tune, but we can't be much help if your tuner didn't datalog the needed points and there was no wideband o2s. So, go get it checked out by a professional or install a WBo2s(preferably a Innovate LC-1) and get a tactrix cable(download ECUFlash and EvoScan) so i can help you.
Old May 25, 2010, 12:30 PM
  #34
im dropping it off tomorrow night to have it all looked at and get a retune...i have a feeling the knock is from me fixing the throttle body to be honest...when he was tuning it, we didnt know the throttle body shaft seals were bad until i started driving around and the car would stall when i push the clutch in and out fast at lights
i do have some logs i found that i can email you ITune...i have boost, air fuel, knock, timing etc....evom wont let me upload the file because its too big
thanks a lot for your help
Old May 25, 2010, 05:21 PM
  #35
dropping the car off tomorrow night!! hopefully i can get closer to 400whp once the problem is solved....say byebye clutch
AbrasEvo
23
Jun 11, 2010 05:44 AM
Malik_EvoIX
Jan 14, 2009 09:19 AM
JVELA
May 24, 2004 04:32 PM
Omeezy
Apr 14, 2003 10:17 PM
LancerBeast
Lancer Tranny/Drivetrain Tech
May 25, 2002 07:13 PM
Quick Reply: coolant temp goes from 192 to 206....why?
