can't boost more than 1.3 bar on 25psi wastegate
so, i have black with 25psi wastegate, was able to boost to 1.7bar(close to 25psi) with EVC off.
now, i can only boost 1.3bar.
did leak test, a small leak around the catch can and near throttle body, all fixed.
drove again, same thing, only 1.3bar with EVC off.
next thing i want to check is the wastegate. how do i check the wastegate? hand vacuum pump?
PS: re did the setting on EVC(based on 1.3bar wastegate) and it's able to boost as targeted boost which is around 1.9-2.0 bar. so, i don't think this is turbo problem.
FP's site has a how to on their site for adjusting the WG rod Check it out here
http://store.forcedperformance.net/m...Lancer-TurboHW
Scroll down to see videos
First set boost the old fashioned way: Disconnect and plug off your EBC. Second, run a length of 4mm vacuum hose directly from the J-pipe nipple to the port on the WGA. Crank the turnbuckle on the end of the actuator rod inward(clockwise) about three to four complete rotations. Do a test run and report back the boost reading on your boost gauge,
def check the wg adjustment. you can test the actual actuator with an air compressor and a regulator but since your not overboosting there is not much point, when they fail they generally don't open
last night, adjusted the wastegate preload, connect the vacuum hose from turbo outlet to wastegate(bypass whole EVC system), ran this am and it's boosting upto 1.8bar.
weird that i did not change anything and all of sudden i noticed that it's only boosting to 1.3 bar.
how often do we have to check the wastegate preload? just don't get it...
BLKCarbonEVO
15
May 29, 2010 09:11 AM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
