Can I reuse these spark plugs?
I might have used the wrong words for some of you guys.
I should have asked "Do these plugs looked fouled?"
I did not mean, "I found these plugs in my garage laying around should I run them?"
What I meant was, "I bought these plugs 3 weeks ago, but couple hundred miles on them, do they look too fouled?"
But thanks, I will go back to stock NKG.
I didn't see any marks on the plugs, but you did mention adjusting them with pliers. I have found that if I leave a dent on the strap it leads to misfires. Or at least that is the only thing I can figure.
As to reuse, why not, 400 miles is nothing, a little fouling will burn off in cruise. I do ask why the plugs are sooty at all. If you are using normal ecu it shouldn't allow a plug to foul.
And as a last remark, if they don't feel right replace them, its not that hard, as you know.
^ Got it. Thanks
Since they are iridium i had to use this method to adjust them:
http://www.modernperformance.com/images/ngk_plugs.jpg
The reason they are sooty with that many miles is, I disable Lean Spool for a while and the car was running ALOT richer at spool. I didn't have time to tune it right away.
Thanks for the help.
xmaciek82x
Dec 14, 2007 05:09 AM
