Idle and Boost problems ( Videos )
Idle and Boost problems ( !!!Videos update!!! )
Well i just bought my 03 Evo 8 a few days ago and I have to say it feels slower then my 95 Eclipse GST did back when i had it and i didnt have that many mods done to it besides 3inch turbo back, Intake and Cold pipe with HKS BOV. I know the Evo has to have more power then what my Evo is putting out . First off it idles rough. Its shakes alil and if i turn the A/C on it get even worse, It threw a code yesterday and i went to auto Advace Auto to get it checked out and the guy said the code said it was to high of a idle???? WTH? The cars idle is running low and shakes, why would the ECU read a "high Idle" ?. My 2nd problem is when and it seem to do it when it wants to while im under boost between 4000 RPMs and 6000 RPMs it just stops putting out power, like it just doesnt want to go. My boost gauge reads between 10 PSI and 15 PSI at that point and the RPMs dont go anywhere, WTH? Boost leak? MAF messing up? Someone help! The car has 96k on her and only mods are stock intake with stock intake box with K&N Filter, Boost gauge and Apexi Turbo Timer. I just put in some octane booster and some shell Fuel Sytem Cleaner after i found out these two problems and to see if it would fix them both but nothing has changed. Should i do a boost leak test and a Compression check? take it to the deal? what? The dealer where i bought the car from said he thinks the clutch was going out but that can be because the RPMs stick and the car doesnt go anywhere, if it was a bad clutch wouldnt the RMPs go higher and the car not go anywhere? Any info would be really great. I love the Evo but it shouldnt feel slower then my GST I had.
Here are the Short Videos i took and i can take more if yall need them. Thanks again
Video 1:
http://www.youtube.com/watch?v=8I0vys5fh-A
Video 2:
http://www.youtube.com/watch?v=70aGCTNUiTE
Video 1:
Video 2:
Log it during a pull and see if it's knocking. If it is knocking and it's bad enough, the car will pull quite a bit of timing and it will feel like it's not going anywhere, sort of what you're describing. Just another thing for you to check out. Boost leak/compression/leakdown are also good ideas.
I was just thinking about that last night when u asked me to log the car. So what type of program do i need to download on the laptop when i get a tactrix cable? and what all does the program do and most importantly will it help me?
JosRacing4G94T
May 3, 2017 10:58 AM
khaled_hourani
15
Apr 24, 2017 04:10 AM
TURBO_S2K
26
Dec 10, 2016 09:53 PM
CovEvo
10
Sep 27, 2015 12:38 AM
Solo II Evo
16
Nov 4, 2008 10:55 AM
