T3 vs T4 1.06 twinscroll housings, any power/response difference?
#32
I wish people would post some graphs for comparison...
I personally have a T3TS3586 w/ 1.06 .... at 28 psi, running out of my single pump and 1000cc inj by 6500 rpms, i still put down 470/420. I believe with some fuel its capable of 550 on pump without a problem. I am sure a T4 platform would yield more HP, i'm not so sure that the T4 would spool as quickly. Since my EBC is now tuned better, i hit 28psi by 4600 to 4700 rpms.
#37
i agree... logs are in order for sure.
we should have a solid comparison soon... we have another t4ts3586 we will be building soon as well... i'll be tuning them both so that should take any biasing out of the equation as well. Cars are modded similarly as well.
I will say something i know for sure and have a graph to prove.... my setup now kicks the crap out of my old gt35 with .82 ar setup i was running prior to this.
#38
You should be able to make more than that out of a walboro and 1000cc's, not much, but some
Scorke
#39
Here is the comparison between the 2 cars. To point out a few of the different variables involved...
- - - - Gt35R w/ .82 A/R / Not sure if it was with a built head or not, can't get a real answer / Different Tuner
____ HTA3586 T3TS w/ 1.06 A/R / Stock head / Tuned by Spec Ops / More room w/ more fuel
#41
Looking at the graph, you can see the potential for the improvement in spool, however the TS setup is running more boost yet is dropping power faster as the revs raise. That 1.06 A/R divided housing is about the same as a 0.63 A/R T3 single scroll housing and it performs on the top end similarly. For it to be a more fair comparison, you'd need to run the same boost and a 0.63 A/R T3 single scroll housing. If you did that, I think you'd see the car make similar top end and the difference in spool would be much less.
#42
This goes along with what I have said before, but two different cars, two different turbos, two different setups. The results aren't "fair."
#43
good discussion. 03white - i believe you may be overlooking the transient and torque benefits that twinscroll offers over singlescroll. Even IF the .63 spooled the same on a WOT dynopull as the 1.06, youre going to have huge differences in throttle response (esp at part throttle points) that the dyno wont show - as everyone who has felt the difference can attest to in this thread.
some more fuel for the fire:
#44
Geoff brings up the main point i believe that everyone overlooks. The throttle response is a ton better. With the open scroll setup, especially with the .82 hotside that was on that one, it sits and waits as boost starts to build then their is that rush when it does finally spool and bam you are in boost.... with the twin, their isn't much wait for build as the entire RPM spool is about 500 rpms faster. Yes i am running more boost in my comparison i posted but the benefit to twin over open is the spool and earlier felt torque. Keep in mind, as you said, the total volume of my divided 1.06 is equivalent to the .63.... that is a .82's power level that is being shown which typically is quite a bit higher than a .63 .... in order to compare spool, yes, the .63 would be a closer equivalent, however my top end power is still higher with this setup than the .63 would typically produce on the same dyno and same car.
On a side note.... this discussion will probably gain a lot of important information for everyone to consider when choosing between the open scroll and t3 t4 twin platforms.
#45
FWIW however, 470whp on that dyno is ~540whp in Dynojet terms, which is respectable for that turbo with a relatively small 1.06 T3 TS housing. However, that shouldn't be viewed real-world limitation for that particular TS T3 housing, which is generating around 600whp on Drifto's E85-running HTA3076 - not too shabby.
Which article is that?
