88mm K1 crankshaft 2.0 liter build. need some advice
Hello :P
First of all, i've used search, but i need more opinons about that item.
My motor build planning 550-600hp, deciding on turbocharger now. Pistons (HKS 85,5), rods (carrilo), bearings (ACL) and stuff is already at my garage. Suddenly i'm understand that my crank isn't in perfect shape and we just haven't good places here to just make it "perfect". So, i can just buy new OEM crank or K1. HKS is really overpriced and have some issues with quality, so let's forget about it. So with which one should i go, OEM or K1 billet one ? Thanks.
Discuss ))
Discuss ))
well, it will take alot of time to ship it to Russia, according the fact that i'm pulling out my motor on next tuesday, it's not my choice, but thanks for the advice )
Very weightly opinion, according to the signature ) Thanks
A word of advice when buying one of these Chinese-made billet crankshafts (e.g. K1, Manley, Eagle, etc.) is never install one right out of the box. Always have every journal checked for correct size, roundness, check the balance, and perform a Rockwell Hardness test at both ends. Yes, this will cost some money, but it's well spent. What I say comes not from speculation, but from real world observation.
FYI
FYI
Many years ago now both WEB and Crower sent batches of camshfts out that were not nitrided Those cams wore down in less than 2000 miles use. i was around for all the threads that popped up with cam lobes wore down from the roller rocker. In short nitriding is very valuable surface hardness. In the case of cams its absolutely necessary for cam to live. In case of engine bearings its nice to have when starting engine (no oil pressure for 2-4 seconds) or when engine detonates. instant 4000psi cylinder pressure slams rod bearings onto crank. If crank is slippery it can live. Non nitrided cranks spin bearings quite easily.
Surface hardness has very little to do with crank strength. It is an eggshell like coating to it will make it stronger. But it is minimal to the overall strength from material used itself in manufacturing the crank. Cranks made in china are going to have breakage potential form the materials used. a factory crank has proven to be about unbreakable.
In short the best crank you can put in you engine is a factory crank that has been nitrided. i have been doing this for about eight years now.
FS[South]: OEM Crankshaft
joezthegame
May 6, 2016 03:05 PM
[WTB] WTB Crank and pistons
ba109296
Mar 29, 2016 06:02 AM
WTB[Northeast]: OEM Crank or Billet Crank
SloEvo12
Dec 20, 2015 05:54 PM
