Trying to tighten Exedy Twin flywheel to crank, no mitsu tool
When I did my previous clutch replacement I simply used flat spare metal with two holes much like what the Evo Moto how-to suggests to hold my flywheel in place so I could torque the flywheel bolts.
This time around I am installing a Exedy Twin HD and I definitely cannot use my "flywheel tool". What would you guys suggest I do? I do NOT have the Mitsu special tool but plenty of other tools. Would a breaker bar on the crank pulley wedged against the ground work just as fine or would I risk breaking something...somehow?
yes thats another way.... you can use a prybar and place it between pin that sticks outta the block for trans also.
http://www.directbuildingproducts.co...0bar%20set.jpg
with that. did it 3 times. just requires 2 people. the crank method only requires 1 person when you place breaker bar off the crank to ground.
2006GSR
20
Dec 28, 2014 05:23 AM
justboosted02
Jul 6, 2008 06:58 PM
