1st gear whining, 5th gear grind?
Well hello forums! I purchased my evo for 14k about 2 months ago, it has 56700 miles clean title and runs good. I recently had it tuned, and now it is at 365hp or 290whp! when I purchased it, it had a weird whining noise in the first gear maybe transfer case? also when I get on the evo, I shift into fifth and it will do a slight grind but if I go slowly into 5th there is no problem?
I have no idea, the car was only driven 500 miles in the year the guy had it, due to him not even having his license and he purchased it from a friend.
I did however, purchase some tranny fluid, rear diff and transfer case fluid!
please help, thanks in advance!
well....there def was a syncro issue in our model...
being on the forums for a while i have seen where fluids cleared it...but as a patch and it came back for some..as others were fine.
you can also try adjusting the clutch pedal a tad higher to see if the 5th gear grind goes away.
itsmeek
Feb 9, 2016 02:50 PM
FS[MidWest]: 2005 5 speed and transfer case.
09Ralli
Sep 19, 2015 06:24 PM
Ichigo0Soul
Feb 9, 2014 02:14 AM
