Abnormal Engine Load?
So I've been having a few strange problems with mm IX lately. One of which I made a post about a few months back and a few more recent one's which I have theorized as being all part of one greater problem. The first of which was my car was just shutting itself off randomly and I couldn't figure out why, no bogging down or anything, it would just cut out. Then I started having a problem making boost, but it doesn't feel like it's leaking or anything, it feels like a fuel cut, like I would have in 5th normally but it occurs in 3rd, 4th, and 5th now. I also noticed that when I hit the clutch and drop out of gear, the car's rpm drops to like 200 and sometimes when this happens it just hit 0 and turns off, this happens more when the A/C is on, or if I hit the clutch and start to turn my power steering cuts out. So I've pretty much come to the conclusion that there is something giving the rotating assembly for more stress than usual. Is there anything on the evo known to cause this problem often? I understand it could be a million things but just trying to see if I can narrow it down based on other's past problems.
My buddies was doing the same thing. He replaced his spark plugs, battery and alternator just before it threw a code for the Crank Position sensor. A weak signal would cause most of your problems.
Enjoi926
29
May 18, 2010 05:11 AM
evodrivesme
22
Jun 26, 2006 03:14 PM
