Any 600+ Evos run a Turbosmart E-Boost2?
Im curious about the turbosmart e-boost to ebc. I like the boost by gear options
really only needing it in 1st gear , but would be more convienent than flipping a switch or retuning the car on a solenoid through AEM.
I know Im just being lazy but am still curious as to any high hp evos usuing them
especially the boost by gear option. Any feedback pos or neg is appreciated. Thanks
Id be interested to hear as well. I have a boost solenoid running through my aem but its a pain to change boost. I'd like over-boost protection and boost by gear or vehicle speed too.
I'm narrowed down to e-boost2 or hks evc VI
in order to run the eboost-2 for boost by gear, you need to set up microswitches at the steeringwheel or the shifter gate and change them manually (@the wheel) or through shifting ( w/ a fabbed up bracket to hold the switcches at the shifter gate).
already talked to turbosmart's tech about it as i looked into the same thing, and this was my only choice(s) of making the boost by gear work.
y not just do a dual stage, and set the switch as a push-button on your steering wheel, or through a micro-switched shifter ball? easiest method imo as you really only need lower boost in 1st on higher hp cars.
im not really sure of the average cost for a turbosmart e-boost but for $850 you can get the best boost controler on the market fwd guys love it and its used on a **** ton of high hp prostar ama bikes
http://www.turboelements.com/index.p...d&productId=74
Yea I have a few honda friends running the NLR ebc, Theres no way in hell is it really neccessary for a awd car to need that.For that price too lol.But it is a badass product I do totally agree with you there. A solenoid through AEM will control boost by gear and everything in between. I was just looking for something quick and easy, that said the basic dual stage mbc will work too. Only the launch [1st gear] needs less boost, after that its game over.
Buschur just came out with a revised dual stage mbc and Ive used turbosmart's dual stage mbc that works great also.
I used a TurboXS DTEC on my old STI and I was pretty impressed with the gear dependent boost control feature it had. Just took a little time to setup to work properly.
I also have the Buschur dual stage MBC and I had it wired into the AEM and at like 40MPH, it switched from low boost to high boost. I used this for a little while, but didn't see any difference in ET/MPH and just opted to leave it on high boost for the whole run.
easiest way imo just do wat slorice said, and have the aem input trigger a microswitch at an inputted mph (whatever is the mph at redline in 1st/begining of 2nd after shifting) on a dual stage mbc.
I have the BR dual stage but I haven't launched the car with my high boost setup so I don't know how it feels nor have i tried to launch with it on low boost and than hit the switch like we discussed previously.
Not to impressed with the Turbosmart. Too much to setup and more than we need for most evos honestly. I would just setup the tables in the AEM. They are there, require no rewire, and are duty cycle based (or can be) so you can ramp vs vehicle speed fairly easy.
Aaron
Aaron
