So you have Meth Injection.. Are your pistons also cracked??
#167
so... how can the meth kit have caused failure?
did it suddenly start working and ended up washing the cylinders?
or did someone drop in a tune that was meant for an Sti with a meth kit? <- if that's the case, of course it's going to blow up. you can't use someone else's tune on your car.
#169
k. i'm confused. LOL.. you said the car wasn't tuned for meth because the kit wasn't working. this leads me to believe the car was tuned on pump gas only.
I believe he said that the friends car was tuned for meth, however, the hole in the line deprived a large amount of meth from getting to the motor. Eg he's tuned for 12.0:1 af ...when his kit was nice and fresh. His meth kit after a few months or year(s) has line in the tubing...the same amount of meth that would normally get to the intake is dropped by a huge % ...his tune doesn't change, the ecu will still deduct whatever amount of fuel he was tuned for a doesn't compensate in time.
#170
At first, it sounded like the meth kit wasn't working when they tuned the car, so we were like "????". LOL
#172
I've run meth injections for over a decade on 3 different cars with no cracked pistons. I know of dozens of people who have also run it for a long time with no problems. I don't think meth was the culprit directly. It's been in use since WWII. I have NEVER seen a piston crack from the proper use of injection.
#173
There are many things that can go wrong with a methanol kit. To some of us, it's just not worth the risk.
#174
To be fair when running meth most people are pushing the limit in terms of boost and the tune. I've never seen anyone running lightly tweaked fuel, timing and low boost while cramming meth in. It's no different then getting a bad tank of gas and detonating on high boost. It's a risk like any modification. One person isn't going to successfully convince me that meth is the problem.
Saying that I switched to E85 about 6 months ago and made considerably more power than meth ever allowed. When it's available E85 is a much better alternative but few people have access to it. Meth injection, installed properly and maintained regularly is not dangerous to run.
#175
I don't think anyone would argue with your post assuming "properly installed" includes a way to evenly disribute the meth to each cylinder evenly.
Some people don't mind the risks of using a meth kit just as some don't mind the risk of running a MBC. To each their own.
#177
My point was ANY modification comes a certain amount of risk. Whether or not it's "worth it" is up to the individual.
Sorry, I probably shoulda included an explaination with my comment. I just got off a 64hr shift. Kinda running on auto pilot. LOL
#179
Im sure I can't convince you anymore than you can me. Even disbursement can't occur completely but at a high pressure through a quality nozzle, atomization occurs. Proper placement of the nozzle insures the charge enters the intake and gets a very good disbursement. Its not perfect but again decades of uae have proven that its adaquate. But as you said to each their own. As with any mod you need to weigh the risks and benefits and find your own conclusion based on the facts, not an assumption.
