LC-1 Very Lean Readings
I just finished installing the LC-1 and did some logging with Evoscan for the AFRs using the LC-1 output. I noticed very lean AFRs and was wondering if it's possible that the sensor is not reading properly. It does read in the range of 14.5 - 16 at idle so I'm guessing it's on the right spot for that. However I'm getting around 13 - 14 during spool up from around 2500 - 4000RPM for load up to 100%.
Would any wiring issues cause it to read incorrectly even if it is reading correctly at idle?
-No longer running alcohol injection
-Knock counts were very low only a knock sum of 2 at 4000RPM
Could the wideband be reporting different numbers with higher RPMs but be fine with reporting values at idle?
Evo VIII 4o1
Jul 27, 2014 03:36 PM
Rokpapaziz
11
Jun 6, 2013 12:30 AM
