How many quarts of oil
Old Jul 10, 2010, 04:27 PM
cruzzinlow's Avatar
Amsoil SSO here. i usualy fill the filter and put in 4 quarts then start her up for a minute then shut it down wait alittle bit and then top off accordingly
Old Jul 10, 2010, 04:36 PM
dabizkit's Avatar
Originally Posted by apagan01
thanks for mentioning my name.
But racing or DD we can hook him up with some good oils.
Is there a huge difference between mobil 1 and amsoil that you can tell?
Old Jul 10, 2010, 04:40 PM
mifesto's Avatar
im not gonna bother reading what others all said but do not go for exact 4.7 quarts. depending on variables, there is going to be some old oil left in there. i would recommend 4 quarts only, then check dipstick and add as necessary
Old Jul 10, 2010, 06:22 PM
apagan01's Avatar
there is a difference, specially if the non EP Mobil 1, also depends to wich AMSOIL flavor you are comparing to, mostly compared to ATM 10W30 ASMOIL whic is the oil mostly used here on evom.
i would be glad to start a thread to compare, or pm you with details or if the OP is ok i can compare in this thread,,, thats if you need me to compare with specs i can do.
Andy
Old Jul 10, 2010, 10:08 PM
UgmWRX's Avatar
Amsoil is good stuff but I am big fan of Mobil 1 EP. I would say a hard choice between the two because most Evo owners will want to change their oil before these extended drain intervals.
Old Jul 11, 2010, 07:50 PM
evo4sho's Avatar
I already had purcahsed mobile 1 Ep. The original owner ran that and changed it every 3k miles and I plan on doing the same unless their's something wrong with that. I read that it could last 15k? But I don't think I'd risk going that far on an oil change. Theirs strong supporters on every site that i visit about Amsoil products. I'm not bashing them but if I'm not having a problem with Mobile 1 I don't see a point in changing. I hear amsoil does make some great 2 stroke oil though.
Svendiesal I appreciate everyones comments and theirs no reason to flame anyone. Thanks for your concern but I didn't mind any of the posts prior to yours, they were all helpful.
Old Jul 11, 2010, 08:01 PM
dabizkit's Avatar
Well, if aint broke don't fix it We respect whatever decision you make. It's your car after all
Old Jul 11, 2010, 08:06 PM
TommiM's Avatar
Does your evo not have an oil dipstick?
Old Jul 11, 2010, 11:19 PM
UgmWRX's Avatar
Mobil 1 EP is a very capable oil. You can check out BITOG to verify that
I definitely would not be pushing 15,000 as the TBN seems to be very low by that point but it meets my needs as an extended interval oil. As does Amsoil.
fast03evo
Jun 14, 2015 05:33 PM
mitsuevodriver
26
May 13, 2014 12:01 AM
Roen
Mitsubishi TC-SST Discussion
Mar 19, 2014 08:29 PM
nrgizeman
Jun 13, 2013 08:44 AM
chase
Feb 13, 2004 08:08 PM
Quick Reply: How many quarts of oil
